Question about Samsung Washing Machines
Broken door handle on a samsung j845 washing machine. i need a replacement.
  • Anonymous Mar 25, 2014
    broken handle
    repair broken handle
  • 750 Answers
Http://www.pcappliancerepair.com/
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
try these two places to order the handle. You will need the complete model number ,
from the sticker in the washer door jam
Please remember to give me a good rating
Posted on Dec 05, 2008
2 Suggested Answers
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Samsung J845 washing machine will not spin.
could be the dampers have failed or the drum mount is broken, try a spin with no clothes, if it is spinning with noise or the drum is not running true it will need major repairs.
Apr 19, 2010 | Washing Machines
D3 error prevents washing machine from working Samsung F/L j845. possible cause door censor?, fuse? can you advise me
Took of the lid Looked at the door connection it had come off I reconnected it and WALLA it works.
Dec 07, 2009 | Samsung Washing Machines
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
Door Wont open on my Samsung J845 washing machine
yes its the door mechanism Unplug the machine for 4 hrs the try opening the door.Don't try to force it you will make matters worse
Sep 07, 2009 | Samsung WF203ANW Front Load Washer
Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Jun 02, 2009 | Samsung WF337AA Front Load Washer
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
J845 washing machine door won't open
Sites for spares.
RepairClinic.com
espares.co.uk
mcminone.com
Apr 11, 2009 | Samsung Washing Machines
Samsung J845 Front Loading washing machine. The door is stuck, it seems the latch inside is broken?? Not sure, but am unable to get the uniforms that are in it out! It did finish its cycle. I just need to...
there is a part on the door that is broken. if your door handle is not automatically springing back to close when you open it there is a small thin piece in the door if you take it off that acts as the safety release for the child proof mechanism. If this is missing then you definitly have to find a new part as this helps to open the door. it is located next to the silver clip andit acts as the holder for the lock i too have the same problem and still are trying to look for part.
Mar 17, 2008 | Washing Machines
Washing Machines Logo
427 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
