Question about Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD Television picture goes black
Is this a bulb problem?
  • stevejones8 May 11, 2010
    The tv was getting darker then this morning I heard a loud pop followed by no picture or sound.
  • Chrisry696 May 11, 2010
    Does it come?
Yas same thing happend to me replaced buld now is fine
Posted on Jan 04, 2009
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture goes out, comes back, sound is fine
I found several instances of this probllen on various forums, and determined that it is the bulb after all. It seemed that a bulb should either work fine or be burnt out, so I thought it might be something else, but so many other customers had this identical problem that I am 99% sure it is the bulb. I found a replacement bulb with housing for about half the price of the Sony Store, so i ordered it. In the meantime, another customer offered a suggestion to try adjusting the Power setting to Power Saving instead of Standard. I tried this last night and the picture worked fine! I will replace the bulb when it arrives and keep the old one on hand in case this happens in the future. Thanks to all of the posters out there!!!
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
No Picture on Screen
They might be a problem with the video section(video card)this is where picture is generated and need to be checked there is a possibilty of a chip getting or has a leak .
The bulb gets voltage from this card so pls check it .
GOOD LUCK DUDE.
Nov 24, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony kdf e55a20 picture goes black sound stays on
Thanks for updates.
Its time to replace Lamp. Please buy original Sony Lamp for Sony TV and avoid aftermarket or compatible parts for good performance of TV.
You can purchase original Lamp form Sony Accessories Store. Just type TV model in search box and see details by click search.
Good Luck
Jan 17, 2009 | Sony KDF-E55A20 55 in. LCD Television
My t.v. picture goes on and off.
Follow up: The audio/video blackouts were in fact a precursor to the bulb going bad ( even though no lights on front indicated such as the manual suggests). Replaced it, blackouts went away. Picture is noticeably brighter, so the bulb was showing signs that I didn't pick up on. If you're reasonalby handy, the lamp assembly is an easy fix for approx $200-$250 .
Dec 22, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E42A10
replace the lamp and you will most likely be good to go.
Mar 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Kdf-e55a20
In my experience with these models, if have found that your fault could be due to a blown bulb assembly. This can easily be checked by looking up the bulb replacement procedure in the user manual. The bulb should look clear and see-through to the tip of the filament. There must be a small class pipe inside which has a wire connected to the tip.
Any white residue or black discoloration inside the bulb indicates a blown bulb. You can contact your nearest Sony service centre for a new replacement bulb. Write down the "XL-xxxx " number as you will have much faster result than giving the model number.
If you need any more assistance please post a reply.
Best of luck.
Mar 02, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E60A20 60 in. LCD HDTV Logo
129 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
