Question about Canon PIXMA MP210 Photo All-In-One Printer
E3 on a Canon MP210
Fitted black Canon cartridge PG40 and am getting an E3 message, any idea what it may mean?
Thanks,
David
  • 2 more comments
  • Karen beltran Dec 05, 2008
    Yes I also have an error message E3 on my Canon Mp210.
  • Tonired Dec 06, 2008
    I am getting the same error message and I know the E3 means a paper jam.. but I don't have a paper jam, never did, no torn paper or anything.. SOMEONE HELP PLEASE!! I need my printer up and running ASAP!!
  • michellesuma Dec 08, 2008
    I am also getting the same code with no jam!
  • Anonymous Jan 06, 2009
    I have the same problem and have found no solution - I worked at a help desk for 3 years and tried all the tricks - think I'm gonna get a new printer and recommend NO ONE buy this printer!!!!!
The same error , im agree NO ONE BUY THIS F... PRINTER
Posted on Dec 22, 2009
Fitted black cartridge 40 and getting an E3 error message
it common with cannon
i put a piece of wire tape on the ink cartridge level gauge so it gives full reading all the time..you get more printing less warnings/errors.
Mar 31, 2016 | Canon PIXMA MP210 Photo All-In-One Printer
Alarm light on and i blinks E3
e3 means paper jam. check for jammed papers inside printer. also check if the carriage that contains cartridges can move freely, left to right and look for obstructons that prevents it from moving
Sep 06, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Hi, My Canon MP210 printer is displaying E3 code. The colour light and alarm lights are illuminated constantly and black one is flashing. When opening the "lid", the cartridges do not align to...
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Mar 18, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
What black ink cartridge is used for this model PG30 or PG40?
Hello, it's Canon #40 or #30 black ink.PG30 and PG40 is the model of the ink. The model of the printer is MP210.
Thanks, Lolita
Oct 26, 2010 | Canon PIXMA® MP210 Printer
Canon Pixma 510 black cartridge
I doubt it very much! Your model seems to use the PG40 & CL41. You can also use PG50 & CL51.
See also my tip on refilling these cartridges.
Feb 01, 2010 | Office Equipment & Supplies
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon MP210 getting E5 message with PG-50
Sadly Canon cripple many of their printers so that they will not accept the high yield cartridges such as the 50 & 51. As a result your printer the MP210 will only accept the 37 or 38 cartridges which are only half filled, or the 40 and 41 which are fairly full, but don't contain as much as the 50 & 51. All I can suggest is that you could try to sell the 50 on eBay, and send a strongly worded email to Canon.
Aug 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma mp 210 printer
i am getting a constant "E 4" alarm for fine print cartridge in position/ However when i turn it off then on to get the cartridges to auto move over to accessible location they do not. they remain hidden behind the right hand side even tho the printer tries to move it. i found a foot long lenght of plastic strip and a splver piece of metal loose inside. feeeling atop the cartridege they appear to be in tightly. they mechanism to move them across does not work. is it worth shiooing to mfr or can i get some repair ideas from you> thanks
Jul 14, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma 210 - Error 5
Just changed black ink cartridge and now getting Error 5. WIll not print at all. I am quite sure the new cartridge is compatible, it a like for like replacement. Is there a way to reset or resolve this issue? thanks
May 29, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Refilled cartridge not recognised by printer (canon PIXMA MP210)
I held down the stop butten for five seconds and now it seems to work fine. Perhaps this could help you.
Nov 14, 2007 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
3,985 people viewed this question
old marine
old marine
