Question about Kendall KANGAROO Pump Sets
No set cannot start pump I get alarm "no set"
  • briseime Dec 25, 2008
    my problem is code 8888 i cant not set
  • Anonymous May 20, 2009
    My hospital has the same problem, one RN reports they had to try eight bags before one worked. Kangaroo asks that the Lot number/ serial # be saved and given to them to help them track down the problem.
There may be a problem with the drip sensor.
If you have primed the pump set and place the drip chamber in the cutout area in the case and
you still get the same error, then return the pump to the company that provided it for you so it can be serviced by a trained technician.
Posted on Jun 16, 2009
HOW TO TELL IF OIL PUMP IS GOING BAD ON 1996 TOYOTA CAMRY??
Low oil pressure will not cause the alarm to set and shut the engine down, usually if there is a switch turning it to off disables the alarm and lets the car start. If the oil light on the dash goes off when the engine is cranking or after it starts chances are that there is no problem with the oil pump. I need to know what the problem is exactly at this time, does the engine turn over but not fire up or does it do nothing at all when trying to start it? Do the dash lights turn on when the key is on? Is there an alarm sound from the horn when trying to start it?
Jul 11, 2017 | 1996 Toyota Camry
My system keeps flashing the 90 code indicating low water flow. My pool is full. What's wrong and how do I get the system to run normal? I just set the pool up and it has flash this cood from the...
Most low flow alarms are caused by the pump stopping before the chlorinator cycle ends. You must set the chlorinator hrs between the pump cycle. Start and set your pump cycle, wait at least15 to 30 minutes and then set you chlorinator hrs and make sure to it completes it's cycle at least 15 to 30 minutes before the pump cycle ends, If your pump turns off before the chlorinator cycle ends, you will get a low flow alarm......
Hope this helps, if it does, please rate...
Jul 25, 2011 | Intex Automatic Salt Water System for ...
Utbd del alarm keeps showing
It's actually "VTBD del" which means the "Volume To Be Delivered" has been set and the pump has delivered that much food. Pause the pump (Start/Hold button), then press and hold the VTBD button (below Start/Hold) for 5 seconds. That clears the VTBD.
Mar 30, 2011 | Kendall KANGAROO Pump Sets
Just brought a 95 jeep cherokee was left for like 8 month so dead battery jumped it and started 1st time with alarm goin and alarm wouldnt stop so had to drive it to mine like that soon as i got to mine...
Try locking and unlocking the drivers door using the key. Usually that will re-set the security system. Also try the rear hatch lock as sometimes that is used instead of driver door.
Jan 13, 2011 | 1995 Jeep Grand Cherokee
Clifford immobiliser unlocks doors, does not start car
Find where your fuel pump relay is and check for power there. Most alarm tech's and alarm system dis engages the fuel pump at there relay's.
Simple things to check is the fuse first then go for the relay and if everything there is working properly, it could be your alarm may have gone bad or your fuel pump it self.
Good luck and hope this helps
Apr 13, 2009 | 1996 Audi A4
Alarm suddenly goes off car will not start
unlock driver door twice consecutively from the outside with the key.
Nov 08, 2008 | 1997 Volkswagen Golf
Engine will not crank, cannot get security alarm to reset
check the fuses for the alarm you might have blown them which would not let you start the car. word of advice never mess with car alarms and never jump your lawn mower with your car.
Sep 24, 2008 | 1992 Chevrolet G20
Kendall KANGAROO Pump Sets  Logo
187 people viewed this question
Top Kendall Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Kendall Health and Beauty Expert? Answer questions, earn points and help others
