How do I connect three Television's while using one sat receiver?
I have one DirecTV receiver (Hughes model HIRD - E1) in the living room and want to connect two other Television's to it. I understand, they would all have to display the same program. That would be OK! What type of splitter do I need and where do I install it at. Thank you for helping us.
Tim
  • 50 Answers
Any coaxal 3way should work. to make it easy put it where it already has a connection such as where it goes into the reciever.have one coming out and going into the box and the other can go off and split off to wherever you want.
Posted on Dec 05, 2008
The remote for the hughes sd-dvr40 will only change the tv chanel even with the button on the remote in the sat. mode it will not change the sat. rec. chanels
I fixed it by reprograming the remote. This is how! Point the remote away from the DVR and press and hold the TV power button and the Directv button on the remote at the same time until the red light at the end of the remote comes on and stays on when you release the buttons. Then press the thumbs down button on the remote (3) three times and press enter on the remote. This corrected my problem which set the remote as a new remote. You will have to reporgam your TV code into the remote to operate the volume on your TV .
Nov 16, 2009 | Hughes SD-DVR40 210-Hours Video Recorder
Huges hdvr2 work on new directv hd service (swm)
Call customer service and ask for compatible receivers at no cost since they upgraded your odu (outside dish unit) and left you with no service in 2 rooms. Let them know how upset you are and demand an answer to why the technician left you without SWiM compatible receivers in all the rooms. Call 800 531 5000 and request to speak with a supervisor. They have the authority to override. If customer service dept does not cooperate then ask to be transferred to the customer retention dept. You will get results there. Remember you are the customer not them. Good luck!
Mar 29, 2009 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Incorrect date in DirecTV programming guide
on front of receiver, there is a door that you can open. behind the door there is a red reset button. press the red reset. this should fix the problem
Mar 22, 2009 | Hughes HD-DVR250
Can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
Mar 10, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
How to connect a PS2 to a TV through a Hughes Direct TV box
unfortunately you cannot run a ps2 or any other device through the receivers. take a look at the tv may have inputs on the front or side of tv where you can use red/white/yellow cabling OR take a look at what type of cabling your tv does support and go from there. hope this helps.
Feb 22, 2009 | Hughes HIRD-E11 DirecTV DTV Receiver
Hughes SD-HBH Satellite Multiswitch Compatability
DiSEqC Tone burst multiswitch are not compatible with directv equip
Dec 31, 2008 | Hughes SDHBH DirecTV DTV Receiver
HUGHES HIRD-2 SATTELITE CODE
LOOKING FOR THE PROPER CODE TO PROGRAM INTO MY hird-e11 remote to operate my Panasonic TV. The tv has built in VCR player if that makes a difference. thank you
Jul 06, 2008 | Hughes HIRD-E11 DirecTV DTV Receiver
Program Code
DIRECTV Model D-10 00001, 00002
Hughes Network Systems (most models) 00749
Hughes Network Systems models GAEB0, GAEB0A, GCEB0, GCEB0A,
HBH-SA, and HAH-SA 01749
GE models GRD33G2A and GRD33G3A, GRD122GW 00566
Hitachi model HDS210R 00819
Mitsubishi HD models SRHD400 and SRHD500 00749
Panasonic models TZ-DBS01 and TZ-DRD100 00247
Panasonic models TUIRD10 and TUIRD20 00701
Philips models DSX5150R,DSX525R/I, DSX5350R, DSX5353R,
DSX5353X, and DSX5375R 01076
Philips models DSX5500 and DSX5400 00099
Proscan models PRD8630A and PRD8650B 00566
RCA models DRD102RW, DRD203RW, DRD301RA, DRD302RA,
DRD303RA, DRD403RA, DRD703RA, DRD502RB, DRD 503RB,
DRD505RB, DRD515RB, DRD523RB, and DRD705RB 00566
RCA models DRD202RD, DRD221RD, DRD222RD, DRD223RD
DRD225RD, DRD420RE, DRD440RE, DRD460RE, DRD480RE,
DRD430RG, DRD431RG, DRD450RG, DRD451RG, DRD485RG,
DRD486RG, DRD430RGA, DRD450RGA, DRD485RGA, DRD435RH,
DRD455RH, and DRD486RH 00392
Samsung model SIR-S60W 01109
Samsung models SIR-S70, SIR-S75, SIR-S300W, and SIR-S310W 01108
Sony models (All models except TiVo and Ultimate TV) 01639
Toshiba model TSR101DSS 00790
Uniden model UDS100 00724
Setup Codes for DIRECTV HD Receivers
DIRECTV Model H-10 00001, 00002
Hitachi model 61HDX98B 00819
HNS models HIRD-E8, HTL-HD 01750
LG model LSS-3200A, HTL-HD 01750
Mitsubishi model SR-HD5 01749, 00749
Philips model DSHD800R 01749
Proscan model PSHD105 00392
RCA models DTC-100, DTC-210 00392
Samsung model SIR-TS160 01276
Samsung models SIR-TS360 01609
Sony models SAT-HD100, 200,300 01639
Toshiba models DST-3000, DST-3100, DW65X91 01749, 01285
Zenith models DTV1080, HD-SAT520 01856
Setup Codes for DIRECTV DVRs
HNS models SD-DVR80, SD-DV40, SD-DVR120,
HDVR2, GXCEBOT, GXCEBOTD 01442
Philips models DSR704, DSR708, DSR6000,
DSR600R, DRS700/17 01142, 01442
RCA models DWD490RE, DWD496RG 01392
RCA models DVR39, 40, 80, 120 01442
Sony model SAT-T60 00639
Sony model SAT-W60 01640
Samsung models SIR-S4040R, SIR-S4080R, SIR-S4120R 01442
10
PROGRAMMING
Jan 26, 2008 | Directv RC23 Remote Control
Second DirecTv box unable to locate a signal
it is multi sat multi sat compatable!My opinion is buy a powerd multi switch you can getem at radio shack or from a sat dealer that will clear p your prolem i belive also check all your rg6 coax ends u may have a a bad splice or a fraid shiel wich will make your reciever do the same thing but hope you can fix it
Goodluck
Please rate
Dec 11, 2007 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
