Question about GE GSS22JFMWW Side by Side Refrigerator
Icemaker stopped i lost power the icemaker stopped the lever lifts up but no water flows to fill it
  • 1 more comment
  • prdragon63 Dec 05, 2008
    the lever lifts on its own no water flows in to fill it up
  • prdragon63 Dec 09, 2008
    thanks the answer you gave me is very helpful it confirmed what i guessed it to be
  • Shane Hays May 11, 2010
    When you say that the lever lifts up, do you mean that you see it go through a cycle on it's own or it goes up when you move by hand?
  • 82 Answers
Ok that means you need a new water valve. That is the part that the water supply from the wall connects to.
Posted on Dec 06, 2008
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Nov 26, 2012 | Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Having a problem with Kenmore refrigerator, model number 106.78862891, icemaker. The water going into the icemaker will not stop. It has a continuous stream of water. The icemaker makes ice when I MANUALLY...
first checkthe inlet solinoid valve if has a continuity or when u energized valve it activate or produce magnet that open the valve and water enter may this solinoid is stuck up try to dismantle. or check or clean the water level sensor using sand paper or rating 1000
Feb 01, 2011 | Kenmore Refrigerators
Icemaker continues to run water for several minutes
Change your icemaker module. It is getting stuck in the fill position. They are about 50 dollars or so and are held on with 3 screws normally.
Sep 12, 2009 | Frigidaire FRS6R5EMB Side by Side...
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Ice no longer being made.
Check the fill tube. It may be frozen.
If it is not frozen, make a jumper wire from a short piece of 14 gauge insulated wire. Strip both ends about 1/2 inch. Bend the wire in half. Insert the 2 stripped ends into the T and H terminals behind the icemaker cover. If the gear on the end begins to turn, let it turn for about 20 seconds, then remove the jumper wire.
When the ice maker completes the cycle it should fill with water.
If it fails to turn. Replace the ice maker.
Apr 29, 2009 | Maytag MZD2766GES Side by Side...
Icemaker fill tube keeps freezing up.
The reason your fill tube to the icemaker is freezing up time and time again is simply the valve, or valves (water valves) that dispense water to the door and icemaker. It most likely always is the icemaker side because it is always harvesting ice and it gets used the most. The only way to stop this is to replace the water valves almost always located in the rear of the Refrigerator with the supply line coming off the wall the valves with one or two electric plugs that energize the solinoid type valve when unit calls for water. Tired of getting out the hair dryer and melting the ice that plugs up the fill tube? This is the only solution. Some of the time is because lime, or other deposits in the water will not allow the plunger to rest in the complete closed position. When the valve is energized for the amount of time needed it lifts the plunger allowing water to flow through. Then when it goes back down
to the closed position it has a small gap that causes water to seep through. There you have it! It's fixed! Unplug unit before replacing valves.If you have a double valve system make sure your lines go back to the original spot. Some of them have a 1/4" line with plastic compression fitting for the icemaker and a 3/8" for the water at the door. Some have both 1/4" compression fittings coming out like "Amana" so once again, make sure to get all lines back to the same possition. Free info. from-
Randy Browne
Appliance Installtion & Repair
San Antonio, Tx. 78209
210-822-1818/210-493-2700, cell# 210-264-1471
Feb 25, 2009 | Frigidaire FRS23R4A Side by Side...
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jul 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Cant seem to get the Icemaker working
Mungah, There is no valve that needs to be turned on. The water travels through the valve into the filter and up to the ice-maker. Try pressing the water lever and stay on it until the water fills the filter and comes out. You should hear the valve energizing. The ice maker cycles every 2.5 hrs. approx. When it calls for water it may take several cycles to prime the line and fill the ice maker...As far as the leak, something is wrong with that compression connection, re-do it and see if it back.
Oct 21, 2006 | Kenmore 44103 Side by Side Refrigerator
GE GSS22JFMWW Side by Side Refrigerator Logo
87 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
