Question about Kenmore Kitchen Ranges
Temperature on range not correct
I have a Kenmore 30" Radiant range model 911.95292992.
I put a temperature gauge in the middle of the oven and set the range temperature to 300 degree's. the gauge only got up to 250 and I noticed that when I tried to vary the range dial temp, the temp gauge in the oven was around 40-60 degrees off. The owner's manual only account for a 35 degree adjustment. What should I investigate to find the problem?
SOURCE: Oven does not heat to proper temperature
get a new oven
Posted on Nov 23, 2007
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
SOURCE: incorrect temperature in oven
refer to the manual about setting the temperature. When the unit ships from teh factory they set the temp. you may need to recalibrate it.
Posted on Sep 03, 2008
Jimster
  • 240 Answers
SOURCE: jenn-air stove temperature not constant
Sounds like your oven probe sensor has got issues. Pretty easy to fix, just look inside oven for the probe (small round cyclinder, about a pencil width or smaller, mounted usually in the back top corners), remove the two screws, then slide it out. Some models have the probes where you will have to take the back off to get to them. If your probe is ok, then you might possibly have an issue with your main oven control, which may be computer or knob type. These (especially if computer driven) can be very expensive to fix, and some need calibration. Good luck and let me know if you need any other assistance.
Posted on Nov 16, 2008
SOURCE: Whirlpool Electronic Gas Range temperature adjustment?
I found the answer on another website.
Posted on Feb 07, 2009
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
General Electric Radiant Slide-in Range JSP39: The oven does´nt work, in the screen appear F-3 very often, and inmediatly it gets off, sometimes appear F-2 and then gets off
These codes indicate an over temperature condition. The F2 & F3 error codes both mention the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
Jan 20, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Oven themostat not set correctly
Your thermomitor may be going or the oven sensor could be the problem. Buy a BRAND NEW thermomitor and put it in the middle of the middle rack and set to 350. After the preheat is done, wait another 10 min and read thermomitor with flashlight through door glass. This will be the MOST accurate way. to tell
Mar 26, 2009 | Kenmore Kitchen Ranges
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
