Question about Panasonic KX-T7431 Corded Phone
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
Is kxt-7431 recive caller id
after installed kxtd-193 caller id card i dont recive caller id on the kxt7431
pleas let me know if this phone doesnot sport caller id
thanks benny
  • Anonymous Mar 19, 2014
    Caller ID on my landline does not work when my EE router is switched on. Can you help?
  • Panasonic Master
  • 2,460 Answers
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Posted on Dec 05, 2008
  • Karyn P Oct 03, 2013
    your solution continues to come up as an answer to my problem, but I don't have the phone you are speaking to. I have a KX-TG4021 and can't get the audio caller ID to work, just the on screen alert. If you have the ans. to this, I'd really appreciate any help. Thanks
How will i activate the caller ID for panasonic kx-t7730 without installing caller id card
caller ID comes from your phone company and you normally have to pay extra for it
Sep 07, 2016 | Panasonic KX-T7730 Corded Phone
I have a panasonic KX-T7130E and want to know how to connect and install it.
It connects to a Panasonic Key Service Unit, pick a number, TA/TES, TAW, KXT, KXTD, and in some cases TDA/TDE/NCP. It's an analog 4-wire system phone, so it requires both voice and data pairs (a 4-pin connection) and a port on the system. You can only connect one 7130 to a system extension.
Jun 05, 2011 | Panasonic KX T7130 Corded Phone
We had a corded KXT7230 installed in our office, my question is does this phone have a Caller ID? I only have a reference guide book. It has nothing in there about the caller id.
The phone doesn't have anything, just a display. The phone SYSTEM may have CID, but not likely. It's connected to a TD system and it need a TD-193 card and has to be greater than 1.0 software to work.
The 193 card fits on top of the trunk card inside the cabinet and covers 4 lines. If you happen to have a TD-308, that CID card has a part number ending in 93 and it covers 3 ports.
Oct 29, 2010 | Panasonic KXT-7230 Corded Phone...
I use Panasonic Kx-T7730 as a propitiatory telephone. When someone calls from outside, All phones on the network ring. It had to ring only on the proprietary telephone.
The 7730 plugs into a Panasonic phone system. That system (KXTA, KXTD, KXT-something) has programming. Each system has a manual or set of manuals to program system ringing. Comment back or search the internet or your files for that manual and it can be reprogrammed.
Jul 14, 2010 | Panasonic KX-T7730 Corded Phone
You need 3 things. CID service from the telco, A TD-193 card in the system, and some programming to make it appear, like a ringing phone or be able to answer the phone after the CID is transmitted.
Which one are you missing?
Jul 07, 2010 | Panasonic KX-T7453 Corded Phone
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
Kxtd816 how to do rollover or call forwarding line busy
Roll over or hunt group is handled by carrier
Mar 18, 2009 | Lands Phones
How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your as long as it is being provided from your phone service and the card is installed.
Feb 20, 2009 | Panasonic Lands Phones
Hi, I have a Panasonic KX-T7636 and I dont see any caller ID on incoming calls. How do I fix this?
Okay well i'll just give you the long and short. If your caller id was working and then it all of the sudden stopped working you need to call your phone service provider and notify them. If you just got these phones installed then you would need to get a caller id card and turn on the caller id prompt from your phone system.
Dec 16, 2008 | Panasonic KX-T7630 Corded Phone
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7431 Corded Phone Logo
576 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
