Question about Philips MX6000i System
MX6000i DVD Playback freezes
Im having problems playing DVD's lately. I insert a disc press play, and half way thru the movie it begins to freeze. At first it will begin to skip then a few minutes later it freezes. I left the system unpluged overnight to see if it's a reset issue but no luck. I also tried diffrent dvd formats and nothing.
shanth
  • 108 Answers
SOURCE: My DVD player no longer plays original dvd's - only copied dvd's
some times when you create DVD movies by high speed DVD writers, your data cannot be read by dvd player with high performance. it s due to speed mismatching. always write DVDs with Normal speed in order to use with DVD players. while in case oof PC-DVD -Rom it does not happens. it can read any high speed wriiten DVDs. DVD-Rom in PC are more precise than DVD players. Some times Weak DVD player Lens system can also mis read.
Posted on Dec 22, 2007
  • 38 Answers
SOURCE: DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Posted on Feb 04, 2008
  • 476 Answers
SOURCE: problems with playing discs
There are several causes for this problem.
1) Faulty DVD drive. Most drives have a dual laser, one for CD, and one for DVD. Check the player with both CD, and DVD. If it reads one and not the other, then it is most certainly a faulty laser. The laser assembly or whole mechanism will need changing.
2) Dirty or dusty lens. If the unit is kept in a dust environment, dust and dirt can be drawn into the machine by the fan. Try using a DVD lens cleaner. If this doesn't work try a CD lens cleaner. (Dual laser - see 1))
3) Condensation. Condensation can build up on the laser lens if the unit is kept in a humid environment. Also, this can be caused by a cold environment. In this case, condensation forms as the unit warms up. In either case, leave the unit in a warm dry environment for an hour.
Posted on Feb 13, 2008
Enquiry
  • 152 Answers
SOURCE: playing a dvd with my system
i think it is a problem due to heating of the reading head... not cent percent sure... but ur description sounds like that only...
Posted on May 22, 2008
CLARKPINK55
  • 71 Answers
SOURCE: picture freezes, dvd wont play or starts stops continuously
the lens on laser needs cleaning manually never use disc cleaners ever
Posted on Dec 17, 2008
Picture freezes while dvd player playing
The problem is in the laser pickup assembly, the stepper motor that moves the laser is sticking on the worm gear or excessive ware on the gear linkage is preventing it from moving.
Mar 14, 2012 | Samsung SWA-4000
Freezes during playback
Hi. What I am trying to establish from my last question is whether the laser has become heat sensitive or whether there is a bit of dust buildup on the spindle table that might be causing the disc to have excessive wobble.
If the disc has excessive wobble, then the machine will have trouble tracking the outer tracks and will constantly skip as you have described after say 30 to 45 minutes.
If the laser has become heat sensitive then the same problem could potentially occur - The only difference being that if you were to restart the movie at that point, then the skipping would continue even at the beginning of the movie.
The first problem (wobble) is easy to fix - Clean the spindle table, the second problem may render the unit uneconomical to repair.
Mar 16, 2010 | Samsung DVD-V5500 DVD Player/VCR
It freezes when playing a blueray movie. it seems
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. Most often, the firmware problem is JAVA related and will not let the menus load at all, but freezing during playback has also been reportedly fixed with the firmware upgrade.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 19, 2009 | Sony BDP-S350 Blu-Ray Player
DMR EZ47V freezes occasionally, will not play certain discs
i hope ,too.if its only months since you bought that ,avail of the warranty package that comes with it.
May 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd pixilating and skipping about an hour and a half into disc
Use a dvd cleaner and then try the movies. Hope this helps.
Dec 21, 2008 | JVC HR-XVC33U DVD Player/VCR
DVD video player problem
your laser is getting weaker now, if you have thoroughly cleaned then it needs a replacement now.
Apr 29, 2008 | Samsung DVD-V4600 DVD Player/VCR
Half-way burn?
Runa thorough virus scan and if nothing shows there, do a system restore...accordianman
Feb 28, 2008 | Sony (DRU720A) DVD±RW Dual Layer...
Dvd playback freezes or is choppy
Get a cleaning disk and run it through the machine. Could be a dirty lens on the laser.
Jan 22, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
Playing the dvd
It's having a problem with the second layer of a DVD-9.
Check if you can see the second part of the movie at all, by skipping directly there or to the credits.
Dec 25, 2007 | Curtis DVD6041 System
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Philips MX6000i System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
