Question about Whirlpool SF357 Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
When I set the temperature and press "Start" to preheat my oven, it doesn't get warm. I pulled the broiler drawer out and could see what appears to be a heating element illuminating. I can also smell gas. Is there an igniter that sparks the gas, or is that what the heating element does? In either case, my oven doesn't heat up. I don't know if this is useful, but the burners do work.
  • 1 more comment
  • rnigro43 Dec 12, 2008
    Sorry for the delayed response, as2871910. I changed the ignitor, and that oven sparked right up. Now I can give my microwave a rest. Thanks, man!
  • vincentaddic Jan 20, 2009
    It seems I have the same problem and I would like to fix it myself, the repairman charges $100.00 just to walk in the house?
    Is there a diagram where its found and where can i but replacement parts
    Also, one of the top burner never lights I also followed the manual to align it but still doesn't work only when i use a lighter.
    I have the SF385 oven
  • luvtaz1 Feb 21, 2009
    wow! thought i was the only one with this problem, I will try to change ignitor, now the problem i am finding is replacing the knobs for this range. One broke and now i cant find replacement. Do you know where i could get replacement? Thanks
I dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Posted on Nov 28, 2009
My whirlpool gas stove accubake super capacity 465 does not ignite or turn on.pls advise.
Jay
Posted on Jan 08, 2011
I pulled the drawer out and watched as I started the oven and seen the spark arcing on the frame of the oven . It turns out a mouse chewed thru the insulation of the wire, so i wrapped it with elec. tape. Problem solved !!
Posted on Oct 28, 2012
I get the parts from searspartsdirect.com
Posted on Dec 20, 2009
    Habit-Forming:
  • 171 Answers
Change the oven ignitor
Posted on Dec 06, 2008
3 Suggested Answers
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
Posted on Jun 10, 2009
marka19
  • 1430 Answers
SOURCE: whirlpool accubake self cleaning super capacity
This sounds like the relay on the main board has failed. You will need to see if you have power going into the control. If you do replace the ERC (main control). You can also carefully inspect the board for burn marks if you see any replace it. Here is a link that will help you check and replace this http://appliancehelponline.com/ovenerc.html
Posted on Sep 13, 2010
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
Prob light stays on, prob is not connected. Will not allow me to heat the oven to a proper temperature or to turn off. Tried unplugging. Frigidaire fggf3054
Press the probe button and hold for 6 seconds.
Press self clean and toggle until "continue" message appears.
Press start to accept.
good luck!
Nov 27, 2014 | Frigidaire Gallery FGGF3054M 30"...
How to turn on sabbath control on my whirlpool stove
To Activate Sabbath Mode:
To use the Warm Zone and/or Warm Drawer during Sabbath Mode,
press the WARM ZONE and /or WARM DRAWER keypad before
activating the Sabbath Mode.
1. Press BAKE.
2. Press the "+" or "-" key to set a temperature other than
350F (177C).
3. Press START.
For timed cooking in Sabbath Mode, press COOK TIME, then
the "+" or "-" keys to set the desired cook time.
4. Press TIMER SET/OFF for 5 seconds. "SAb" will appear in the
display.
To Adjust Temperature (when Sabbath Mode is running):
1. Press the "+" or "-" keypad. Each press of a keypad will
increase or decrease the temperature by 25F (14C). No
temperature will appear in the display.
2. Press START.
To Deactivate Sabbath Mode:
Press and hold TIMER SET/OFF for 5 seconds to return to regular
baking or press CANCEL/OFF to turn off the range
Feb 09, 2013 | Kitchen Ranges
When I set the temperature and press "Start" to preheat my oven, it doesn't get warm. I pulled the broiler drawer out and don"t see anything illuminating. My oven doesn't heat up. I don't know if this is...
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Whirlpool SF357 Gas Kitchen Range
Gas oven not lighting
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 03, 2010 | Kitchen Ranges
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
May 23, 2009 | Kitchen Ranges
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
Whirlpool SF357 Gas Kitchen Range Logo
6,165 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
