Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
Honeywell Envirocaire Whole House humidifier not elevating humdity in home. Installed sev. years ago by HVAC contractor. Can't get the humid. above 30% no matter how high I turn it up. It is fed by hot water line, changed the pad, and the fan runs when the furnace fan is on. I leave the furnace fan on all the time, to no avail.
  • Anonymous Feb 16, 2009
    Does not dispense any moisture. Hooked up to the hot water
This may not be a solution, but a couple things you might want to look at. First, the humidifier may not be big enough for your house - just because a contractor installed it doesn't mean he sized it right. Second, humidity may only be 30% locally by the humidistat, but higher in other parts of the house - it depends where the humidistat is located. Finally, look at your hot water line - I'm surprised he ran it off hot water and not cold - seems like a waste of energy to me, but the feed line may be clogged by sediment from the water heater
Posted on Dec 05, 2008
Water runs continuosly on my Honeywell Envirocaire Elite system, no matter what setting I have the automatic humidity control set at, should I try replacing the Kip valve #3703?
Try to disconnect the main power to the unit and if the water valve is still open and water is running, you have a bad valve (the valve stuck open). Tap on the valve body it may help on sticking it, if not replace it.
Feb 17, 2013 | Honeywell HE360A1027 Whole House...
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
Honeywell HE260 housing melted/deformed
Humidifiers are made from a very durable heat resistant plastic. If it melted or warped you have a serious overheating problem. That plenum should not get over 140 to 155 degrees. If this furnace is running to hot it could stress and crack your heat exchanger. Install a good carbon monoxide detector in your home!!!! Check your filters. Check your airflow. Make sure all registers in the house are open. Is your blower speed set high enough? If this furnace is operating to hot it is definitely worth the investment to have a pro look at it before you replace the humidifier.
Is this overheating problem new? Or was this something thar happened years ago and may have since been solved But you are just now noticing the heat damege that was caused.
Goog luck
HVAC Teacher
Mar 07, 2009 | Honeywell HE260A1010 Whole House...
High Calcium in Water
Hi, Hot will make the problem worse. If your calcium is that high you will have scale in your tubs, sinks and toilets. Calcium is a pipe clogger and if you have noticed this type of scaling you may be wise to consider a whole house water filtration system, it will save you lots of problems in the long run. Good Luck!
Feb 19, 2009 | Honeywell HE220A1019 Whole House...
No increase in humidity after installing whole house humidifier
have you checked the damper ? is the motor running the right direction ? have you increased the water supply to it ? you need to be sure that it is coming on only when you have a call for heat, normally your humidistat should be installed near the return, or on the return duct, for proper sensing, you could try holding a pan of steaming water, placing the stat above it, not to close, to see if the stat shuts off the hum, a little trick, that way you will know if the stat works ok, hope these helped, thanks for the question, mr.grzz
Jan 22, 2009 | Honeywell HE220A1019 Whole House...
Aprilaire 500 - Everything works, but humidity will not increase!
You should take out that aprilaire and throw it in the garbage or return it to who you got it from. Ask them why they didn't offer you the best humidifiers available. The only way to truly control humidity in your home without running your heat is a steam humidifier. Autoflo makes a good one also honeywell makes a new one. I have installed a honeywell tru steam in my own home and a few customers it hasn't lived up to its advertising. The auto flo has never given me any problems with customers.
Dec 18, 2008 | Aprilaire 600 Humidifier
Honeywell he220a waterflow
Sounds like you Connected the humid trans fromer directly to a main power source. It should be either on the EAC or HUM term on the board of the furnace.
Dec 11, 2008 | Honeywell HE220A1019 Whole House...
Humidity not going up
I have a similar problem with mine too. I am interested to see if anyone can diagnose this problem
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
272 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
