Question about Microsoft Xbox 360 Console
Sent a game invite to someone on friends list, it won't accept, I
Have not had that problem with anybody else on my friends list when I invite them or they invite me, just with one friend. How do I correct this problem?
5 Suggested Answers
  • 4 Answers
SOURCE: online play with ps3 cannot invite friends to play Call of duty?
try to install new network
Posted on Apr 14, 2008
  • 10 Answers
SOURCE: Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Posted on Jan 09, 2009
  • 11 Answers
SOURCE: My ps3 Friends list has gone
i Need Help With This 2 Mucked up nd it Happend Str8 after i Played on Playstation At Home Nd i Dnt Think Some 1 Has Hacked i Need Help With it Tho Help Plz
Posted on Aug 22, 2009
  • 60 Answers
SOURCE: my xbox 360 wont let me accept game invite and
your NAT type is most likely not open. To connect to certain people, you have to have compatible connections.
Posted on May 17, 2010
My friends list will not load in Double Down Casino
This happened to me...so I started to type friends names in the search bar just above the loading sybol and it loaded some friends to the page so i just selected all and it sent invites......hope this helps
Jan 14, 2013 | Evermoremedia DoubleDown Casino
Lost turbos on farmville, not getting gas i earned, also banned from invites for no reason
shouldn't have sent 100 invites out everyday. your friends got tired of it and flagged enough times.
Apr 22, 2012 | Zynga Farmville
How to use video camera while chatting
Hello there.
Here is some information from Yahoo! about how to start your webcam!
If this was helpful, let me know with a couple thumbs up! :)
To start a webcam conversation:
  1. Select Messenger ' My Webcam. The "My Webcam" window opens.
  2. Select Actions ' More Actions.
  3. Click Invite to View My Webcam. The "Invite to View My Webcam" window appears.
  4. Select a friend from "My Contacts" or click Other Contact and type the Yahoo! ID of someone not in your Contact List.
  • Your friend will receive an invitation message on their computer to accept or decline your invitation.
  • When your friend accepts, a conversation window appears on your screen.
  1. Type your message in the text area at the bottom of the Conversation window.
  2. Select Conversation ' Close when you are finished.
May 02, 2011 | Yahoo Messenger
Can't set up private game online How do i set up a private game with 2 players online I go to game and other party does also and we can not hook up together
If you are playing the same game as a friend, you can press the ps button and bring up their name in your friends list, press triangle and select either join game, or invite friend. But first you have to be inside a pregame lobby in order to invite someone. If however you are connecting via LAN which is linking two PS3's together then you have to use the LAN setting instead of online play.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Invit a friand in modern warfare
The problem is most likely your friend is not accepting, the 'MW2' invites are different to previous COD's, they are sent as a message, rather than in game pop-up.
Nov 13, 2009 | Video Game Consoles & Games
My daughter in law had a facebook account and she invited me to be a friend on hers and I did. However at the time I did not have a facebook account and now I do. I have sent her an invitation to be a...
Facebook is not iPhone specific. You could be on your laptop or PC and let her be on her iPhone. You both can still chat with each other. To use Facebook on PC just visit the site www.facebook.com and login when it opens. Select My friend and you will see her there if she has accepted your invitation. Else you can invite her again.
Nov 03, 2009 | Facebook Computers & Internet
I want to know how do I play someone in my ps3 that lives in vancouver,BC. How do I invite someone to play me?
what kind of game do you all want to play?if you add them as your friend it would make it the invite or chat room better. then all you would have to do is invite them from your friend list.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
