Question about Dishwashers
New kenmore dishwasher and it is sitting too low there is a quarter inch at hole at the top of the dishwasher under the counter. It seems to be tight in the space; can we cut off the metal bracket that screws in under the counter. That way we can raise the dishwaster the quater inch. I think it is tight enough not to move around without the top screws. What is your opinion?
  • 750 Answers
No do not remove this bracket. if you remove this bracket the dishwasher will tip forward when you ope the door!
Why would you want to change anything by cutting a bracket? What is the matter with it!
is your dishwasher doing something unacceptable????
Posted on Dec 05, 2008
Granddaughter stuck wooden pastry brush in dishwasher in door opener. How do we get out.
She was just trying to help!!
  • Assuming it is the main door and not the detergent dispenser door,
  • Carefully remove screws securing washer under the counter. They will be above the main door screwed directly into the underside of the counter. I would expect only two.
  • Check to see if the machine is free. If so provide some protection under the feet as you pull as not to mare/scratch the floor. You can only lift it a little. If it is to tight than you may have to remove the kick plate and screw in the feet to allow for the unit to slide out from under the counter.
  • Slide the machine out about 4 inches. You should be able to see the door hinge and spring mechanics. There are drain hose fill hose and power wire attached to machine but they should have at least 4" of slack to allow for access.
  • Cut the pastry brush out. Reinstall washer. Locate previous screw holes in counter and install screws into the holes .Do not over tighten the screws into the counter. Do not let them go into the counter to far and mess up the top of the counter.
Thank the granddaughter for all her help and that Santa will be here soon!!!
Dec 04, 2015 | Dishwashers
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
The brackets to hold the dishwasher back under the counter do not align with the holes that were drilled in the granite counter top for the old dishwasher. I do not want to try to drill new holes in the...
You could have a handy person make some new brackets which attach to the new dishwasher's brackets with bolts but are made so that they line up with the existing worktop holes. You can probably use strips of soft metal with holes to fashion these.The dishwasher may have to sit slightly lower.
Dec 30, 2010 | Dishwashers
How do i remove this dishwasher
There are a couple of screws up into the counter top...remove them, disconnect the drain hose, the water supply and the electric supply.... then just pull the dishwasher straight out away from under the counter...
heatman101
Oct 13, 2010 | Kenmore 24 in. 16539 Built-in Dishwasher
What holds the dishwasher under the counter top
There are 2 screws that hold the dishwasher in place. To see the screws open the door all the way. Then bendover and look at the underside of your counter top. You will see the screws on both sides about 3 inches in from the sides.
May 11, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Kenmore dishwasher spray arm too low, hits heat element bracket
There is a picture of the inside of what I believe is your dishwasher. It is not great but might give you some idea of what might be missing. http://www.bobgolds.com/dishwasher/home.htm
Feb 24, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwasher de-installing
You may be able to push it back in and place a piece of quarter round molding down at the floor with nails to prevent it from coming out again.
There should be some kind of clips if you look under the front edge of your counter. The clip or clips should have holes for screws that will screw into the underside front edge of the couner top.
Feb 09, 2008 | Bosch 23 in. SHU 8805 Built-in Dishwasher
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
