Question about Philips GOGEAR SA6045 MP3 Player
My earphone plugin
Well, my gogear fell on the ground and apparently the earphone pugin doesnt work now!
Please hlp me fix it because i've tried alot of new earphones and only one side of the earphone works.
So something's wrong with the hole.
How can i fix it?
Sounds like your stereo jack got damaged. Mine has the same problem. Possible to fix......worth it?
Posted on Dec 11, 2008
How do I enable pugins
Open our chrome browser.
Type chrome://plugins/
Dec 31, 2015 | Google Chrome
My Philips GoGear Raga 2GB is not working properly. Its earfone jack socket is causing some problems, it doesnt give proper sound now!
The fault could be the earphone, check the earphone in a different device/player, if the fault still appears the the earphone is faulty, probably a broken wire in the cord.
If the earphone is OK then the earphone socket in the MP3 player is faulty. If may be too expensive to repair, unless you can DIY.
Sep 14, 2010 | Philips Audio Players & Recorders
Sound comes only in one earphone..
your headphones probably blew in the one ear. Try another pair of headphones.the same thing happened to me. if that doesnt work the recepters in the ear jack youll have to have a professional to fix it
Feb 28, 2010 | Philips Audio Players & Recorders
Problem with my mp3player please help
Have you tried to reset it. If not, try to hold down the power button while pushing the volume button up. That helps alot.
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
The sound isn't working
Well it could be that your earphones may have broke or its like you said when it fell something may have happened or buy your self a new pair of earphones.
Jan 03, 2008 | Philips GOGEAR SA6045 MP3 Player
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Aug 28, 2007 | Philips SA1100 MP3 Player
Only one earphone works
Might be Broken conns internally in Ipod try another set,And try putting the jack in vaseline and then Plugin and out several times to Clean the Contacts Let me Know ttech
Jul 23, 2007 | SanDisk Sansa e250 MP3 Player
Lock up
Sounds like the ground connection (-ve) to the earphone socket is broken.
When you plug in the earphones, they ground through the control section on the board. Poor sound is another sympton of this problem.
If you have any soldering experience, dismantle the player, and re-solder the 4 connections to the headphone socket.
May 18, 2007 | Philips PSA232 (512 MB) MP3 Player
Sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
Oct 04, 2006 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
160 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
