Question about Car Audio & Video
How do i fix this problem? i set up Three 8" JL Audio (not sure what W's it is but im positive its not a W7) with a 800 watt Fosgate Amp. i have a Alpine CDA 9811. The problems come when i turn the volume up high then it starts to cut off when the bass is thumpin. Not sure what to problem is or how i go about fix'in it. Any help is appreciated.
    Sergeant:
  • 302 Answers
Your speakers aren't strong enough to handle the current from the amp, 8" speakers connected to an 800 watt amp? You need MORE SPEAKER than that.
Posted on Dec 05, 2008
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Jan 11, 2017 | Rockford Fosgate Car Audio & Video
Which amp goes with 2 jl audio w3v3 4 ohm
Choosing a amp isn't always easy but it first begins with what you want.
--RMS of the speakers is what you want to use to find your amp.
That's going to tell you what watt's your speakers can REALLY handle @ 4 ohms.
--Also what you want to spend $$$ will determine how clear it sounds.
--I prefer a Rockford Fosgate amp for base and kenwood for highs.
--Also look at the RMS watt's rating to find the proper power and go a bit beyond what you want so that the amp performs with ease.
--Last but not least you chose the amp for how many speakers you are going to connect to that amp. For example if you are using 2 JL audio 12" for subs, then a mono amp is perfect. But if you are connecting 4 speakers, you should begin to find the amp with four channels so that you obtain left, right , front and rear sound.
Mar 16, 2010 | Jl Audio Car Audio & Video
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Want my 10s to beat down the block
http://www.crutchfield.com/p_020DPX1155/Clarion-DPX11551.html?tp=115
http://www.crutchfield.com/p_675FRT1500/Rockford-Fosgate-T1500-1bd-Factory-Refurbished.html?cc=01&showAll=N&tp=115
http://www.crutchfield.com/p_136GMAX/JL-Audio-G-Series-G-MAX.html?showAll=N&tp=115
http://www.crutchfield.com/p_57515001BD/Rockford-Fosgate-T1500-1bd.html?showAll=N&tp=115
Here are a few amps at Crutchfield.com you can look at. Notice that the closer to a class D you get, the price more than doubles. I have 2 Kenwood 12's that are 800W Rms, and I have a cheap SPL 1500W amp pushing them. 148.5 Db in a 93 Eclipse, so don't worry too much about the class unless you have money to burn. Let me know if this helps :)
May 25, 2009 | Lanzar OPTI1200D 2000 Watt Class D...
Sub not very loud
Hey buddy your question caught my eye because i have a buddy that was wondering the same thing not so long ago-and im no expert but i have had my run with rockford fosgate amps and a few sonys as well. So first of all if you know fosgates well you know that they ALL put out more power than what they are rated at -example your 400 watt fosgate amp is rated at 400 watts but if you got it new than it came with a birth sheet that shows you how much its really putting out-im just throwing a number out there but its probably closer to 480 actual watts. Now you get the sony amp and it says its a 1000 watts but its all bs -it actually is rated at 400 continous usable watts- so the reason that its not any louder than the fosgate is because you bought an amp with almost identical power output. The other part of the problem is that you are limited by your speaker-you could buy an amp that actually puts out 1,200 watts and plug it right in to your sub and its going to probably blow within 30 seconds or quite possibly catch fire. The numbers when dealing with car audio that you have to pay attention to are the R.M.S. power ratings - never look at the peak or max wattage because its all bs and yea its all bs- As i was saying you are going to be limited by your sub because as it stands right now you cant put much more power on that thing without blowing or roasting the coil. All subs have a limiting factor as to how much air they can move- this is called X-MAX and that tells you how far the speaker cone actually moves from start to peak excursion- once you have supplied the speaker with enough power to reach its x-max then thats it -no matter how much power you put on it it wont move any more air than that-and you will create heat and distortion if you try and thats just begging for a blown sub. If you want it louder than upgrade your sub to something that will move some serious air like a jl audio w7 or orion hcca subs -those subs can get it on like dammmmm or easier than that get another sub and then your moving twice as much air at a fourth of the price of buying a balls out jl w7-anyhow good luck with that
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
Old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
