I need to cancel my auto re-charge on my monthly subsription. When I enter my password the screen does not re-act in anyway. The passport entered is correct but the software does not process anything when 'OK'' is clicked.
    Problem Solver:
  • 12 Answers
If you cannot open the software to find a website or email address do a search on google for the company that makes the software and contact them directly to cancel.
Posted on Dec 05, 2008
How d I activate an external antenae
1. Press TV to select the TV mode.
2. Press POWER to turn on the TV. The STARTING SETUP function
begins and the language setup menu appears on the screen.
Press upArrow (^) or downArrow (v)to select your desired
language, then press ENTER.
3. Press (^) or (v) to select TV or
CABLE, then press ENTER.
4. Press (^) or (v) to select START, and
then press ENTER, which
starts the AUTO SETUP.
Note:
To cancel the setup and return to the regular TV screen, press (^)
or (v) to select CANCEL and press ENTER.
5. When the AUTO SETUP is complete, the regular TV screen
appears.
Notes:
• AUTO SETUP of channels may take 15-30 minutes to complete,
depending on your regional cable service.
• To cancel the AUTO SETUP and return to the regular TV screen,
press EXIT.
from TV manual that uses a CT885
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEcQFjAD&url=http%3A%2F%2Fwww.hdtvsolutions.com%2Fpdf%2F50hp66_om_e.pdf&ei=_KppUvWPNqjSyAHTr4DIAg&usg=AFQjCNGar3aphbJ5yNHl9QMUJsSI6SjCTQ&bvm=bv.55123115,d.aWc
Aug 15, 2013 | Toshiba Ct885 Remote Control
Hi. i lost my password of my Projector Benq MP610, with code 22504-15078-7347-9687. i'm looking ford to your help.
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting->Change Password 2. Press Left or Right (button). A "Password Change" message displays. 3. Enter the old password. i.If the password is correct, you can go on to enter new password.
IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __
ii.If the password is incorrect, a "Password Error" message displays. Press Up to try again or press Down to cancel. 4. Check the new password. i.Pressing Auto completes the procedure. ii.Press Up to try again. iii.Press Down to cancel the set-up and return to the on-screen menu.
Mar 10, 2011 | BenQ MP610 Multimedia Projector
Good afternoon sir,i am sachin patel and my friend lost his passport so pls give advise for getting passport number from online way.
1st step : A memory aid can help remind you of your password. If you have entered a password hint in your user account, you can access the hint on the Welcome screen. To display the hint, click the question mark (?) that is next to your user account.
2step: How to set a password hint as a precaution
  1. Log on to your computer.
  2. Click Start, and then click Control Panel.
  4. Click your user account, and then click Change my password.
    1. Enter your current password, enter a new password, and then enter the new password again to confirm it.
    2. Enter the password hint, and then click Change Password.
      1. The change will take effect the next time that you log on.
      Note If you want to keep your existing password, you must enter it as the current password, enter it again as the new password, and then enter it one more time to confirm the password.
      Thanks and regards Chetan Patil
Dec 25, 2010 | Computers & Internet
Hi I am forget my password for wd smartware please help me
During the boot up process you will see on the screen press delete to enter set up
Press delete during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Oct 18, 2010 | Western Digital My Passport Essential SE...
Forgot my password
hope this helps
Sep 29, 2010 | Western Digital Passport WDXML800UE...
Password Error
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera
switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Press enter to confirm 5 digit mode
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode
Mar 18, 2010 | Bushnell Trail Sentry 11-9200 Digital...
I have a BenQ Projector MP610. I lost my password and now i cannot use my projector. I get the code: 22504 13898 6789 8507. Please help...Please email me the decoded password... vmonacillo@yahoo.com
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right4 for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting > Change Password. 2. Press Left 3 or Right4. A “Password Change” message displays. 3. Enter the old password. i. If the password is correct, you can go on to enter new password. IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __ Keep this manual in a safe place. ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to try again or press Down 6 to cancel. Password Setup Enter Password Press Auto to Confirm Press 5 or 6 to change number Press 3 or 4to move 0 0 0 0 Password Setup Do you want to use 0 0 0 0 as your password? Yes Auto No 5 Cancel
Feb 17, 2010 | BenQ MP610 Multimedia Projector
I am charged $8.31 on my Mastercard and I want to cancel account
Go to the pogo home page log into your account, click the My stuff button at the top of the page
click on my account
click on view your subscription info
enter your password
click continue
then on the upper right click on Cancel Subscription
Jan 09, 2009 | Video Game Consoles & Games
How do I enter the User ID codes for a Xerox CopyCentre 275?
The Tools menu is used to set up machine parameters. The menu is protected by a system password, referred to as the System Administrator password. The default system password is 1111.
NOTE: If the System Administrator password has been changed or forgotten, contact Support for additional assistance.
  1. Press the [Access] or [Access A] button on the Control Panel to enter the Tools Mode. The Login screen will be displayed.
  2. Enter your password using the numeric keypad on the Control Panel, and then select [Enter] on the Touch Screen. The Pathway Options screen will be displayed.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button on the Control Panel and re-enter the password. To cancel the operation, press the [Cancel] button. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
Sep 09, 2008 | Xerox Office Equipment & Supplies
Changing the time on the KX T7735
To set time on KX-T7735:
Press (Program)
at "PITS-PGM NO?" press * then # then enter your password default "1234"
at "SYS-PGM NO?" press 000
at "Day/Time Set" press (SP-PHONE)
date is displayed on bottom with year flashing, enter year on keypad "09" for 2009/
press right arrow to make the month flash, press (AUTO ANS)/(MUTE) button to cycle through months.
press right arrow, then enter date on keypad.
press right arrow, and (AUTO ANS)/(MUTE) to cycle through days of the week.
press right arrow, then enter the hour.
press right arrow, then enter minutes.
press right arrow, and (AUTO ANS)/(MUTE) to cycle through AM or PM.
press (AUTO DIAL)/(STORE) to save the date and time.
and you're done =D
Mar 31, 2008 | Panasonic KX-T7735 Corded Phone
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
