I have an acer aspire one 120 gb with one gb ram. it was runing fine went into sleep mode. now the power light is on but there is nothing. I have turn the computer off and then back on again many times with no effect. there is no hard drive sound and the screen stays dark with no sounds. only the light comes on for the power button and the fan.. any help would be great... fixer 307
  • Anonymous Jan 16, 2009
    quand je mets mon acer aspire one en mode stand by, l'ecran s'éteint mais le bouton vert reste allumé Mais je n'arrive plus a rallumer l'écran
    Sergeant:
  • 302 Answers
Your video card is out. replace it
Posted on Dec 05, 2008
Put acer aspire 5734z to sleep mode and wont turn on next day
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptop into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptops.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Mar 19, 2014 | Acer Aspire 5734Z4386 Notebook
Just stopped and nothing since
If you can't hear anything when you try to switch it back on then the problem resides in power http://www.pcworld.com/article/2025425/how-to-pick-the-best-pc-power-supply.html
Mar 03, 2014 | Acer Aspire Z5801 All-In-One Desktop PC...
Ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Oct 16, 2009 | Acer Aspire 5735 Notebook
ASpire one Acer wont turn on.
Pretty new system, so try on just AC power (remove battery) failing that, get in touch with Acer for repair under warranty
Jun 29, 2009 | Acer Aspire 5100 Notebook
My netbook wont boot, i turn it on and i will hear the fan but nothing else, i was using it everything was going well, the batery ran out and it went into sleep mode, i pluged it in and since then i canot...
Leave it plugged in for about 10 minutes. The battery just needs to charge a little more. Then you can come out of sleep mode.
If it is locked in sleep mode. Just hold the power button down to shut off the computer. Let it charge, you can now reboot, and keep charging after about ten minutes.
Jun 28, 2009 | Acer Aspire 5100 Notebook
Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Feb 16, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
Nb acer aspire 7520G - black screen (no light) on startup - starting from sleep mode
Pull the battery and unplug it.
Plug in the AC adapter and see if it boots.
if it does shut it down and reinsert battery, problem solved.
if that doesnt do it then i would check that your ram is seated properly and try swapped between 2 ram chips in both sockets (if your laptop has 2 sockets.
Hope this helps!
Nov 28, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
