Question about Sampo SME-34WHD5 34" TV
Component inputs not working.
Sampo is still working through all inputs but the component. When hooked up directly from dvd player to component picture is very squigly. Did not always do that. When signal is fed through my DVDO line doubler, the picture is there but very poor image quality (very pixilated). Where can I find a new input circuit board?
Ajkill
  • 2035 Answers
SOURCE: I have a 42" Sampo-PME42S6
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. this not work check the cable try yo use another pair of cables ,even this did solve your problem then you need contact the company if under warranty ,if its out of warranty then you need get service from local TV repair center....
Good luck..
Posted on Sep 12, 2008
  • 9 Answers
SOURCE: Image Board Assembly
I have the board, email me at masterhu @yahoo.com
thanks,
Plasma/LCD expert, source of parts/boards.
Posted on Sep 13, 2008
SOURCE: Blue and green lines. no color
I have the same exact tv this sounds like a previous problem that we experienced we resolved ours by plugging into a grand video console. Good luck! Tammy woodpros01@yahoo.com
Posted on Sep 27, 2008
  • 152 Answers
SOURCE: My monitor Goes blank after about 2 seconds
Dave, You failed to state if these monitors are LCD/FPD or are they old tube type? I'm going to assume that they are of the flat screen lcd type. all monitors of the lcd type need what is called 'backlighting' to display the video information. In your case, maybe the inverter power supply board has detected a fault and go's into immediate shutdown mode. the inverter supply is what lights the long slim cold cathode fluorescent tubes (2) that are used for lcd backllighting in 98% of all small screen lcd monitors. There isn't a lot you can do about these types of failures. You can check with Sampo and see if they have a swapout program where you send old monitor plus some cash and they send you a refurbished ( new tubes+inverter board ) monitor. I myself kinda lucked out when a co-worker brought in his Dell lcd. we opened it up and found some bad capacitors that couldn't take the heat generated inside the case. Yes we unsoldered and replaced them with new and it worked. But that was pure luck. could have been a lot of other things wrong too. you might want to surf around and check out slectronics.net/ or other sites that deal with monitor CCF tubes and inverter repair. the lighting technology you are dealing with is similar to the new 'curlie-que' energy saving-screw-in light bulbs! Hope this helps you out some. I'm lmistyrel @ aol or louie12fix on fixya.
Posted on Mar 04, 2009
SOURCE: hello experts I recently came into ownership of
i don't know how much the new one cost but it is fixable. Check the components around flyback transformer , check bad connections, check the flyback it self. It ask some expertise . If you can't ask help for your neighbor technician if he is good you will pay little money. but not less than $80
Posted on Sep 18, 2009
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
DVD Hookup
The input buttons on the remote are shared, e.g. for component, press once for component1 and twice for component2. Same for HDMI inputs. If I remember correctly, the video button is shared by the composite input and the svideo input.
Or you can use the input button on the remote to get each input directly.
Please check what the DVD player is configured for. For 480p (PS) it can only output through component.
Dec 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Sampo SME-34WHD5 34" TV Logo
24 people viewed this question
Top Sampo Televison & Video Experts
Mohamed Ismail
Mohamed Ismail
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
