Question about Kenmore 24 in. 15932 Built-in Dishwasher
I bought a used dishwasher when I start it it makes a loud noise
It make a loud noise when I tried to do a test run. And there is a leak from below. It was leaking at first and I took the cap of the disposal and now it is draining ( thanks for the tip). Could you help me with this. Thanks
  • 750 Answers
It is most likely leaking from the drain or supply tubes you must remove the dishwasher again and check the tubes for a loose band or clamp. Or a cracked hoes!
Posted on Dec 05, 2008
Very Loud Noise when dishwasher starts
It is likely the sound is coming from the rinse aid dispenser solenoid. (I am assuming you do not have a water softener unit on your dishwasher). Try to run the drawer on a Rinse cycle and see if the noise is still coming.
Apr 21, 2013 | Fisher and Paykel 23 in. DD603H SS...
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 | Dishwashers
Kitchenaid Dishwasher has starting making a real loud noise
Hi Andy and welcome to FixYa. I am Kelly. That loud noise your hearing is the motor bearings. If you were to remove the lower kick panel you will prbably find signs of a slow leak of water has been trickling through the motor and you will see a water spot under the motor pump assembly.
You were correct in your assumption that it was bearings. What happens is the motor shaft ceramic seal starts leaking long before the home owner even notices it. Then the water gets into the motor and corrosion starts to build up. As the motor turns the bearing starts to spal as a result of the corrosion and you hear the loud noises.
The only fix for this sadly to say is a complete motor impeller assembly replacement. If your model number is the one associated with this post / question: KUDI01FLSS then there is one more digit after the last "S" that being one of the following numbers 0, 1, 2, 3, 4, 5 or 6.
The motor and impeller for your dishwasher Item 10 or 18 can be found here and is listed at $138.44:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164895&diagram_id=907556#d907556
The seal that has failed is item 23 of the same link. Changing the seal at this point will not stop the noise.
Thanks for using FixYa.
Kelly
Apr 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher has starting making a real loud noise when running. sounds like it might be the motor or bearings or something! Still working fine, it's just very loud!!! Andy ideas?
It could be the motor bearings, they can go out if the pump seal starts to leak and moisture gets to the motor bearings. If that is the case you are looking at about $180.00 for the sump and motor (parts only).
It could also be something caught in the sump near the chopper that is creating the noise. Here is a link to some clean out instructions if you are up for trying them.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Dishwasher loud in beginning cycle and drains early
sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
