Question about HP DeskJet F380 All-In-One Printer
Printer is offline
How do i get it online Hi the printer cartridge was change and the printer went to offline
why does it do that and how do I put it back on-line?
Thank you;Harrey
  • 65 Answers
If you open your "printer's and faxes" folder you can right click on the printer and select "use printer online". Another thing that you want to do is make sure that the printer is ready and no alarm lights or messages are showing.
I hope you find this information helpful.
Posted on Dec 05, 2008
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
Printer says offline and cartrige light is flashing
Check whether the ink cartridges are properly installed.If installed incorrectly they can cause the printer to go offline.Install them correctly.
Also check whether you're running low on cartridges ink and replace if need be.
Sep 27, 2011 | HP Deskjet 6940 InkJet Printer
Cant change status offline to online
hi there!
just go to control panel - printers and look for the icon of your printer, right click on it, look for use printer offline/online and click that. if it still said its offline, restart the pc and the printer. =)
Apr 06, 2011 | Office Equipment & Supplies
Printer showing Offline status
hi
  • Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Jul 05, 2010 | HP DeskJet F380 All-In-One Printer
    HP Deskjet F4180 colour lights flashing and printer offline
    Hi I have exactly the same problem, and can't scan or make copies. I went to HP Online, and tried their advice, which didn't work. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566&rule=25623〈=enHP's solution made me realise it might be a scanner problem. I made a wild guess and kept the cover above the glass panel open. Turn off your printer, lift the cover up and turn on again. The lights should stop blinking and you should be able to scan/copy/print. I guess the cover prohibits the device to scan properly causing the blinking lights. Hope this helps!
    Jul 01, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    IT SAYS ITS OFFLINE, I NEED IT ONLINE.
    perform the syeps below if you are using XP Operating SystemL
    Step 1:
    Determine if the printer is paused or offline :
    1.Open the printers folder, if necessary.
    a.Click the Start icon.
    b.Click Control Panel.
    c.Click Hardware & Sounds.
    NOTE: This step is not required when using Classic view in Windows Vista.
    d.Click Printers.
    2.Right-click the name of the printer and then click Open.
    3.Click Printer.
    4.Verify that Pause Printing and Use Printer Offline are not selected.
    5.Press Esc to close the window without making any changes.
    Step 2:
    Check for the default printer and USe printer Online in the printers and faxes folder.
    Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
    Apr 06, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
    PRINTER HP DESKJET D2360. PRINTER OFFLINE IS NOT GOING ONLINE. I HAVE INSTALLED "CATRIDGE WORLD" CARTRIDGE.
    after installed some refill cartridge printer status show offline and just change other cartridge is ok
    Mar 09, 2009 | HP Deskjet D2360 InkJet Printer
    HP DeskJet F380 All-In-One Printer Logo
    175 people viewed this question
    Seeker5211
    Seeker5211
