Can not use wireless internet without the ethernet cord plugged into the labtop
  • Gus Gaglio
    Gus Gaglio May 11, 2010
    What kind of laptop? what kind of wireless card? what type of wireless router?
    Have you installed the drivers for the wireless card?..
    Bottom line you are NOT using wireless when you plug in the Cat 5 ethernet cable...
    Need additional info to be able to help you.
    "Don't Fuss Ask Gus"
    Problem Solver:
  • 12 Answers
Go to your control panel and under device manager/network adapters check to see if you have any exclamation marks, if you do it could be the drivers or the wireless card itself. Try the drivers first if that does not work then you might have to replace the wireless card.
Posted on Dec 05, 2008
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
How to hook up to new computer
1.You should have a modem you received from your ISP (Internet Service Provider).
2.Plug the Ethernet Cord Into the Internet port of your router.
3.If you have a desktop computer plug in the ethernet cord into one of 4 ports of the router.
4.Open you wireless connections and connect to the internet.
Mar 20, 2011 | Belkin Basic Wireless Router
How to connect to the internet
You should have a home modem from and ISP (Internet Service Provider) Also If you have a router you need to plug the Ethernet Cord (the cord that looks like a Giant phone line) into the internet port of the router, Now if the router is a wireless router and you want to use the internet wirelessly you need to open your wireless connections and you will see your router in the list. Simply double click the connection and it will automatically connect for you. If you do not have a wireless router and you want to connect more than one computer to the internet,Simply keep the ethernet cord plugged into the internet port on the router and you should have 4 other ports next to each other. Plug another ethernet cord into port 1 and plug into the back or side of computer. That's it. I hope this helped have a good day
Sep 29, 2010 | Computers & Internet
How can i get my internet to work on my labtop with no ethernet ?
You can purchase a usb Ethernet adapter that plugs into the side of your laptop. You could buy a wireless card that could fit into your computers card slot.
If you mean that you don't have Ethernet in your home you could go wireless and use whatever free access you might find. Check out an electronics store for improvised attachments. Many types are available.
Feb 19, 2010 | Compaq Computers & Internet
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Red light
Can any computer connect to the internet?
You said you connected the computer with the cable to the 2wire using an ethernet cord, did it go to the internet?
Do you have a modem connected with the 2wire? (not a computer modem)
Do you have the DSL package or Cable package from Time Warner?
Aug 24, 2008 | 2wire 1800HG Router (RG1800HG00)
Ethernet Cord for Router?
I want to tell you that how can you get your password back or reset your wireless password.
1. Work on your wired computer which is connected with the netgear router using ethernet cable
2. Make sure on the rear side of your netgear router you can see four ethernet slots and one internet slot.
3. One internet slot is only for your ISP modem and rest of the four slots you can use any computer to connect with that using ethernet cable.
4. Click on start - Run - then type in "cmd" press enter and you will get black screen. under the black screen just type "ipconfig" you can see some information on your screen search for default gateway numbers.
5. Once you get default gateway open IE and type those numbers without anything else then press enter.
6. It will ask you for user name and password by default "admin" and password is " password "
7. Once you click ok it will open netgear setting page
8. On the left side you can see wireless setting which is under "setup" then click on that option
9. On the middle of the screen you can scroll down that page at the bottom you can see your security key or passphrase.
10. Or you can type new password on the same screen and apply those settings
11. Now try again to connect your device wirelessly enter you existing password or new password which you have setup.
12. Make sure one thing more on the left hand side you have option called "Router Status"
13 Once you click on that at the middle of the screen show you router status and you can find the option called "internet port"
14. We are getting ip under internet port
15. If we re getting ip address then you can simply try to connect wirelessly otherwise please run setup wizard to configure your router. you should getting ip under internet port.
I believe these steps help you to resolve your problem
Thanks & Regards.
Jaspreet Singh Saini
Aug 22, 2008 | NetGear RangeMax WPN824 Wireless Router...
Computers & Internet Logo
David Payne
David Payne
