Question about Sharp AL 1631 Copier
Print quality issues
Prints having missing sections and blank white spots. what could it be? thanks.
    Problem Solver:
  • 10 Answers
Hi slytek the usual problem is damp paper do a copy and put the same sheet back through if the problem has gone then your paper is damp hope this helps regards Dr Bob1(uk)
Posted on Feb 23, 2007
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
It has somes spots on the side of the sheets and I cleaned the cartriges and the spots isn't gone.
A print quality defect in which pages contain random spots or splotches (click on the link to see sample http://bit.ly/mRX3qz) may occur after the replacement of a supply item or the clearing of a paper jam. If your printed output resembles the example shown, please do the following:
Print the Menu Settings page to check the levels of your consumable supplies (i.e. items such as toner cartridges and photoconductor units). Supplies that are at or near the end of their functional lives can cause various print quality issues independently of the operation of the printer.
If any of your other supplies are low, replace them to see if this resolves the issue. Instructions for replacing supplies can be found in the User's Guide.
It is always advisable to print the Print Quality Pages to get a detailed look at your printer's output. These pages allow each color plane to be viewed independently to determine if the issue is with one color (possibly due to a single supply item), or with all the colors (indicating a more general issue with the printer).
If the above checks show that everything is normal, the print quality issue is probably a temporary situation which sometimes follows supply replacement or paper jam removal. Printing 5-10 additional pages should allow the issue to clear up on its own.
If the print quality issue does not clear on its own, please contact Lexmark Technical Support
Apr 04, 2011 | Lexmark C532n Color Laser Printer
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Dec 04, 2009 | Gestetner DSc232sp Copier
Printer goes through motions to copy doument but pages are blank
From Kodak's website: Question : Why are prints from my all-in-one printer blank? Answer : There may be multiple reasons why your prints are blank. To resolve this problem, we have an easy Step-by-Step Solutions and Repair tool.
Within the tool, select Print quality, then Blank prints.
Start @ this link:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=10355
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Zebra 110Xi III Plus Thermal Printer print quality degredation
You can try cleaning the print head with some isopropyl alcohol and a swab but be sure not to touch the element with your fingers that can get grease from your finger on it causing the oil to burn out the element very quickly. You can also check the Print head element its self. What you are going to be looking for are white spots or streaks on the print head. If you see white spots or streaks your print head has reached end of life and needs to be replaced. If instructions are needed on how to remove the Print head and or identify what DPI Print head you have installed please let me know I can post something up for you. If a Print head is needed please let me know as well. I currently carry them in stock new.
Thanks
Rory Cardenas
708-597-4222 x240
Dec 13, 2008 | Zebra 110Xi III Plus Thermal Printer
Sharp AL 1631 Copier Logo
44 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
