Furnace amana gui090b30b will not ignite when gas valve releases gas, but will if I blow to assist it while the surface ignitor is glowing, how do I fix?
  • robert west Dec 17, 2008
    i have the same model furnace. when the ignitor heats up it does not ignite the flame, I use a liter stick to start it. I replaced the ignition box and the thermastat rod and the ignitor. It worked last year and now its doing the same thing. I replaced the ignitor this year but it is still not firing up without assistance from an actual flame.
  • Armando Bernal May 11, 2010
    Hello, can you clarify "blow" do you mean literally blow into the gas chambers while the valve is open and ignitor is glowing? Thanks
  • 1,420 Answers
Are you saying you put your face in the burner box and blow air on the burner tubes? You are a braver man than I. Gas pressure or air adjustment. Get a technician to check your system or shave all the hair on your face and head before you burn it off.
Posted on Dec 05, 2008
Whatdoes an oven igniter do as opposed to the oven bake igniter?
Initors work with oven safety valves and open gas safety valves when the amp draw changes as the ignitor heats up. Ig niters light the flame and then become a thermocouple and send back confirmation of ignition to the central control. The model above uses a glow bar ignitor which is wired in series with the oven control and safety valve. The most common mistake when diagnosing the ignitor is working is you see it glowing. But that does not mean it is strong enough to open the bi-metal inside the gas safety valve which requires a minimum of 3.5 amps to bend the bi-metal so it will release gas to the burner. -PawPaw.
Dec 12, 2013 | Amana ACF3355 Gas Kitchen Range
Amana furnace. The furnace goes through the cycle but wont ignite. I have already checked the ignitor.
Try blowing out the jet Burners with compressed air especially the one nearest the Ignitor. Right through where the gas comes in. These can get dusty and cause ignition failures. Also check to see if the Ignitor is in the path of the burner and has not somehow gotten bent. 100 or so ohms on the Ignitor should be good.
Oct 10, 2012 | Amana GMVC80905CX Gas Furnace
Ignitor glows but short cycles
Ignitors don't "blow flames". But a defective ignitor can glow but not draw enough current to allow the gas valve to open to the burners.
Replace the ignitor. It's the "weakest link" and most likely part to wear out through use in the ignition system.
Sep 19, 2012 | Amana NGD5200TQ Dryer
My Amana GUI090B30B furnace will not ignite. The ignitor glows then the valve releases gas but the gas does not ignite. The ignitor goes out and the valve shuts after a second or two of trying to ignite...
Hello, it is possible that even tnough the ignitor is glowing it might be too weak to ignite the burners. I would cneck the resistance of the ignitor with a multmeter, should be between 40-90 ohms typically
Nov 28, 2011 | Heating & Cooling
Fan is blowing in furnace, thermostat raised 10 degrees over ambient temperature and not heating home. Red and green lights blinking intermittently on control board.
Cycle the power first & see if the furnace goes through the normal sequence of order. On a call for heat, the vent inducer motor should turn on and the pressure switch should prove negative draft in the heat exchanger. the board then should power the ignition phase whenter it is hot surface ignition, or spark, you should hear a spark or see the orange glow of the ignitor & the gas valve is timed to turn on. If you have proper gas to the furnace, it should allow the gas to flow through the gas valve & ignite the flame. Once the flame is ignited, the romote or local sensor should sense the flame & the blower then kicks on from the time delay in the board. If you don't have any ignition, then something is wrong with either the ignitor, ignition module, pressure switch, or you have a manual limit that is tripped(this looks like a small 1/2 inch disc with a reset button on it) If you have ignition & the flame lights, but drops out, then your flame sensor is dirty & needs a touch of sand paper to clean it up(this looks like a 3 inch metal rod opposite of the ignitor) Make sure your power is off when you clean the sensor if you need to. Also if there is no ignition & the vent inducer motor is running... if it is hot surface igniton, there is a molex plug on the leead wires to it- disconnect & check continuity- should be under 110 ohms.
Sep 03, 2011 | Goodman GMS90703BXA Heater
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
Furnace has automatic ignition pilot light comes on for about 10 seconds then goes back out and furnace blows cold air
Check and make sure you have gas on to the unit and to the gas valve in the furnace.. Check for 24 volts at the gas valve at the furance. Check and make sure the knob at the gas valve is in the "on" position. If you have voltage at the valve than the valve has failed. If you have no voltaged at the valve than the circuit board has failed. One last thing you can check if you do have voltage at the valve. When the hot surface ignitor is glowing orange tap on the gas valve with the handle of a screw diver. Sometimes the valve sticks. Of coarse if this works it will probably stick again. Replace the valve in this case.
Jan 25, 2011 | Heating & Cooling
Ten yr old Goodman residential furnace won't light even though hot surface ignitor glows red for 1 or 2 seconds.
Make sure you have gas on. Tap on the valve as the ignitor glows. The valve may just be stuck. If not- I'm thinking the funace needs a new ignition module.
Jan 17, 2011 | Heating & Cooling
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
