Question about Microwave Ovens
Amana microwave comes up with an F 4
When I try to sensor cook it will not work, otherwise it does cook and heat on reheat and defrost
  • Microwave Ovens Master
  • 9,098 Answers
Your temperature sensor is defective.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You can download Amana owner's manuals and installation instructions here.
Posted on Dec 07, 2008
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Monday evening I used it was for heating hamburger buns. I used sensor reheat and it worked perfectly. Tuesday evening I wanted to defrost a small beef roast. It worked for 1 minute then shut down...
try unplugging it. or the probe might be defective. another trick is slamming the door when shutting it, if this works it;s a micro switch thats gone bad or out of alignment
Jul 14, 2017 | Panasonic NN-H504WF Microwave Oven
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
MMV1153BA brand new, less than 2 weeks
The magnatron may need replaced..(this is what makes it cook)
Dec 10, 2008 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
