Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Reconection of water
Hello- you responded to my question for removing the panel, i posted another question as to how to reconnect the water: thanks so much for your help! I copied my post here:
Thank you. I wish that I would have read this before I disconnected the water. the actuator has been fixed for a few days, but I got so frustrated with trying to reconnect the water to the panel, that I set it aside. Are there any tricks? I hope I do not have to end up calling someone out, JUST to reconnect the water. There does not seem to be enough "give" to put back. In the emantime, I have an "out of order sign" now on the door. Please help! Thanks!
  • j42noto Dec 05, 2008
    AWESOME....i knew there had to be a trick....i will try and let you know. thank you!
    President:
  • Frigidaire Master
  • 2,651 Answers
Sorry, bout that thought i had answered that issued(pehaps for someone else), you can dissconnect the water supply from under the freezer door( quick disconnect fitting). this will allow you to pull extra line into the dispensor area, then simply push through the hole, re-attach the dispensor mech. then reconnect the lower connection
Posted on Dec 05, 2008
After changing the water filter the water dispenser stopped working. How do I fix this problem?
Hello friend, thanks for your post!
Based off the information you have provided I would check to assure the panel is not locked, if it is hold down the lock icon to release the lockout feature. You should also remove the water filter and then install back maybe the connection was not fitting properly. Please comment back if those steps did not correct the problem. I look forward to helping you. -Matt
Sep 16, 2014 | Electrolux Refrigerators
Aqualux Whirlpool Bath controls not responding
Unplug, every thing, take batteries out of remotes etc, remove power from all parts.I mean every parts. leave out for about a minute. reconnect all. try then
Dec 02, 2013 | Home
How to change filter
Hello Connie - Thank you for your post! The filter is recommended to be clean after 250 hours of operation and when the FILTER RESET light illuminate. Some air conditioner filters can be removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well. Once the filter has been cleaned, to extinguish the light simply press the FILTER button and the unit should resume to normal operations. However, if you are referring to a filter replacement part, most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). The part number for the model number posted above FAC107P1A is 5304448298. If you have any additional questions, please feel free to reconnect!
Jul 17, 2013 | Frigidaire FAC107P1A Wall/Window Air...
Water is not spraying in dishwaher
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory systems .
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 10, 2012 | Cars & Trucks
Auto transmission does not respond,. dashboard indicator not working. driving third gear only
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you remove the positive battery connector and let it sit for at least 5mins. before reconnecting it. This will reset the system and can get your vehicle back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
Oct 13, 2011 | 2007 Hyundai Santa Fe Limited
After a wash there is water on the bottom of the unit
Hi and welcome to FixYa I am Kelly.
Water in the bottom of the unit is a sign of drain problems that are usually external to the dishwasher. You probably have noticed cloudy or spotted dishes post cycle lately also. Since I suspect a drain problem here is what you should do:
  • Start at the sink connection and remove the hose. Then clean out the port at the sink or garbage disposal connection. Reconnect the hose. (Clogged garbage disposal ports are the 2nd highest reason for dishwasher drainage problems.)
  • Next if you have an Air-Gap installed pull off the upper/outer cover and NOTE the position of the internal cap and nut. The cap with the inner inverted U will only install correctly in one position. Remove the nut and lift off the inner inverted U cap. (This is were most clogs are found.) Clean out any debris found. Use a flash light and inspect the lower outlet hose port for obstructions. Remove the lower outlet hose to the sink / garbage disposal connection if necessary to clean the outlet port.
  • Lastly... If after doing the above and you still have water in the dishwasher post drain cycle then TURN OFF POWER to the dishwasher and remove the lower kick panel. Then remove the drain hose from the pump and inspect the port for obstructions. Clean as necessary. Re-install the removed hoses. (Check all) Install the lower kick panel.
TURN ON POWER and test the drain cycle after filling with water. This should make it work properly again unless there is a problem with the pump impeller blades or something inside the sump housing blocking the drain port. If you have done all of the above and you still have the same water in the sump post drain cycle problem... Just respond here and I will explain what to do next.
NOTE: If you respond for any reason PLEASE include your model number so I can include any available diagrams to help you in my next response.
Thanks for choosing FixYa,
Kelly
Mar 31, 2011 | Whirlpool Dishwashers
When cycle is finished there is still water in the bottom of the dishwasher
  • Lastly... If after doing the above and you still have water in the dishwasher post drain cycle then TURN OFF POWER to the dishwasher and remove the lower kick panel. The remove the drain hose from the pump and inspect the port for obstructions. Clean as necessary. Re-install the removed hoses. (Check all) Install the lower kick panel.
Kelly
Feb 27, 2011 | Bosch 24 in. SGS43C12 Classixx...
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
I printed a very long IRS manual yesterday, and printer tries to repeat this rather than accepting a new document to print. It's like the Sorcerer's Apprentice! He couldn't turn the buckets of water off...
Hello, again.
I just responded to you a few moments ago in Premium.
As I said, I would suggest first resetting the printer via Printer System Prefs. If still a problem, then remove the printer icon, disconnect the USB cable, repower your system, reconnect the USB cable and reinstall the driver.
Hope this helps.
Sep 01, 2009 | Computers & Internet
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
