Question about KitchenAid KAWS850L Top Load Washer
Top loading kitchen aid washer that shakes down the house
I have a top loading kitchen aid washer that was shaking so bad i thought the whole house would fall apart. i assume it is a problem with the agitator--and i've opened it up to see what's going on, but is there a special tool to unscrew the bolt? when i try to turn the wrech, it just moves the whole agitator.
could there be another problem causing it to rock so badly? the manual is gone, and i dont know what model it is.
thanks
  • Anonymous Mar 26, 2009
    The tub is shaking veryyyyyyy bad and i found a broken spring but do not know where it goes.
  • gpm1 May 17, 2009
    I found the balancing spring hanging loose but cannot determine where it should be connected.
    President:
  • KitchenAid Master
  • 2,651 Answers
Probably wouldnt look under hte agitator for problem. although the trick is to hold t he agitator while loosening hte bolt, it will then lifts right off after bolt removed., i would remove hte cover and perhaps look for a broken spring , bleach sometimes falls through rusting out metal brackets
Posted on Dec 08, 2008
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Front loader washer shakes house
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 06, 2010 | Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jun 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washer shaking
first make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Feb 12, 2009 | LG WM-2077C Front Load Washer
New front load washer shakes my whole house
remove the shipping material...read install instructions that came with owners maneul
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Unbalanced load
If your washer goes severely off balance you need part # W10112113 to fix it.
Nov 25, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
KitchenAid KAWS850L Top Load Washer Logo
348 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
