Question about Motorola Mobility RAZR V3
Motorola key board does not light up when it is flipped open
When I turn my phone on the keyboard lights up while it is starting up. After it starts up the keyboard lights go out. When you open the flip the lights do not go on. Any way to fix this problem.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
You have to change the flex cable(ribbon).take it to a technician
Posted on Feb 15, 2007
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
DOES IT SLIDE OPEN AND HAVE A KEYBOARD
Motorolla L7 do not slide open and do not have keyboard, the only this it has is the keypad on the gront panel.
Motorolla L7 does not slide nor flip, it is flat phone that as all its function keys on the front panel. It does not have a keyboard either, it only has a keypad whivh is common to all phones.
Take care.
Jul 19, 2010 | Motorola Mobility SLVR L7 Cellular Phone
The light of the keyboard does not turn on
you check the wire of the key board sit properly .or may be they have a  lost contact ,check the back of your PC between the keyboard and the CPU ROOM.
Apr 14, 2010 | Motorola Mobility L6 Cellular Phone
None of the keys work on my motorola v9 except the on and off button.when i flip it open it open it ask's me to enter SIM PIN but i cant type anything in
Try the menu to dead the keys, in the same menu/photo where you turn off the answer by flipping it open or using the on key.
Aug 11, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Does not conect to cell phone What is the
First fully charge bluetooth.close bluetooth flip/turn on power by press button in the midle and open flip look blue light not flashing ok for pairing.if not do again and again,pairing only light stay on no flashing.
In phone go to bluetooth function/bluetooth turn on/searching devider ok/enter 4 zero ok.sucessful for pairing.
Jul 10, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola V3 Razr Keyboard will not light up
Are you getting sounds from the dial pad? It should default to momentary lighting, but it can be adjusted for longer time. It sounds faulty, did you purchase a refurb?
Oct 31, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola H700
First, you will need to put the H700 into pairing mode. Look at the last digit in the part number for your headset (there are 3 versions). If it "A" or "B", do the following... 1. Starting with the headset powered off (flip closed), hold down the Call button for 1 to 5 seconds until the light is steadily lit in purple. 2. With the light steadily lit, flip out the boom. The light should remain steadily lit in purple. If the light is flashing, or if the light starts flashing anytime before completing the steps below, the headset is not in pairing mode, and these steps will need to be repeated. If you part number ends in a "C", do the following... If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple. If the headset has previously been paired with other devices, first ensure those devices are turned off. Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple. And finally, you will have to follow these instructions on you A900... 1. While in standby mode, press the Menu/OK button 2. Select Tools (9) 3. Select Bluetooth® (4) 4. Highlight Yes, using the navigation keys, on the Enable Bluetooth® prompt 5. Press the Menu OK button to enable Bluetooth® 6. Select Bluetooth® (4) 7. Press the left soft key for Add New 8. Highlight Search, using the navigation keys 9. Press the Menu/OK button to begin search for new device 10. Highlight the desired Bluetooth device, using the navigation keys 11. Press the left soft key for Add to List 12. Enter Passkey "0000" press the Menu/OK button, you will get a brief message stating pairing 13. Press the left soft key for Done 14. At the Trusted Devices screen, press the left soft key for Connect 15. You will get a brief message stating connecting 16. After being connected you will return to the Bluetooth® Trusted Devices screen Hope this helps. Good luck
Jun 24, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Its stopped.
dear check when u push the power button then it shows some light in key pad if then may be lose connection from cable or display ic is crrupted. other wise check software. mosty it prob from software first check for software.
Mar 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
112 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
