Question about Sharp R-930AK Convection/Microwave Oven
Sharp R-930 not heating up to temperature
In convection mode, things have been taking longer to cook than they should.  I recently bought an oven thermometer and placed it in the oven.  The temperature is significantly lower--150 to 200 degrees, than what I have set the oven at.  What to do?
  • Anonymous Mar 07, 2009
    the last two times I used convection, the temp was about 50-75 degrees to low.
  • fxca Mar 11, 2015
    See if inside -side fan is turning, that blows in the hot air from element. You should orange glow if the element is working. This may narrow down the problem.
  • Sharp Master
  • 9,098 Answers
It may be the thermistor, heating element, etc.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The manual has complete disassembly, test and part replacement info, as well as a very good troubleshooting chart.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Posted on Dec 07, 2008
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
Sparp R 930 not heating, turntable not turning
I just repaired mine with the same symptoms. I found that the bottom microswitch on the door (there are 3 switches) was faulty. It started as open, when the door closed, the switch closed (good), but when the door was fully closed the switch was open again. I went to Electronic City with the switch in hand, they found me a duplicate that cost me $2.50. BTW - you must take out the door switch assembly, 3 screws plus wires, in order to work on the switch. Also, put the assembly back in so that the door latches close/open the switches correctly. -jk
Jan 14, 2010 | Sharp R-930AK Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
MICROWAVE RUNNING. DON'T HEAT & TURNTABLE WON'T TURN
your magnatron needs replaced! (It may cost less for a new one then to fix this one!)
Dec 09, 2008 | Sharp R-930AK Convection/Microwave Oven
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time....
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Aug 12, 2008 | GE Microwave Ovens
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Cooking in an old convectional microwave
Regardless of the model, the basic procedure should be the same in most Sharp convection models.
You can download several recent models here:
http://www.sharpusa.com/products/TypeManuals/0,1083,5,00.html
Nov 22, 2007 | Sharp R-1850A Convection/Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
225 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
