Question about QMark Heating & Cooling
Loud kickspace heater
I just had a TPI-TSH20J, 240v, 2000w kickspace heater installed and it is very loud. Would a comparable Qmark heater be quiter and worth the switch? Thank you, Michael
2 Suggested Answers
  • 625 Answers
SOURCE: Noisy kickspace heater
it probably is a sealed motor but if you have access to it you may be able to oil it with a very thin oil - like 3 in one oil. the bearings are undoubtedly oil-lite which is a porous bronze bearing pressed into the end bells of the motor. for fractional horsepower motors I'd go to grainger dot com to see if a replacement can be found.
Posted on Feb 02, 2008
Hey. I’m about to purchase the PLF2004 240v Hydronic Baseboard Heater 2000w. My question is, do i need to pull a neutral?
240v will be 2 "hot / 120" wires and a ground. Refer to the factory specifications for amp draw and be sure you run the right size to handle the load and use a breaker properly sized as well.
Nov 25, 2017 | Heating & Cooling
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
My Qmark electic heater keep tripping the breaker
You will need to provide additional diagnostic information. Most likely the breaker is defective. Warning: potential for injury is HIGH working on power electrical! Do not attempt if you do not have experience and training. Proper personal protective equipment and methods should be used. The running amps needs to be measured when the heater is turned on. Find the rating on the breaker and calculate 80% of this rating. The heater current should be less than this value. If the breaker is tripping when less than 80% is measured it is most likely defective. Measure all power legs on the heater. Also check the nameplate info on the heater Volts, Amps. Compare these values to the actual.
Feb 06, 2015 | QMark MUH (0521) Compact Heater
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
Do I need the toggle switch when unit is on a thermostat? TSH20X
the toggle switch can be left conneted, make sure it is on could remove it but it doesnt matter if you do or not
Oct 18, 2009 | TPI Set of: TSH20X and TSH1TX Fan Forced...
Can I wire two heaters on one source? I have model RDH2010 (1000W/2000W)which is 240v. I am using 220 wiring,
One, double pole, 20 amp breaker feeding the two heaters will be okay IF you have #12 AWG wire and NO other loads on the circuit. 4000 watts will pull 16.6 amps, that's max for a 20 amp circuit.
Sep 26, 2009 | Dryers
Heater sizing
12000 btu's per 500 square feet is a good rule of thumb
Jul 19, 2009 | Fahrenheat Electric Convector Baseboard...
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
4awg is about the size of battery jumper cable. or 240v multi-strend cable. and 48A is big. double 40A brakers.
the heater is 208v 3-phase 34,000BTU
it is call out to use the 240 comercial wiring.
Sep 10, 2008 | QMark MUH-35 Heater
Heating & Cooling Logo
62 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
john h
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
