Question about Bosch 24 in. SHU43 Built-in Dishwasher
Water doesn't pump out
There is always standing water after cycle completes
  • Anonymous Dec 08, 2008
    Yes, I have the same problem, the water doesn't pump out and is soapy.
  • Anonymous Dec 09, 2008
    I just started having the same problem and am looking for a solution/idea.
    Mine is an SHU 3000 series, about 10 yrs old.
I had a similar problem with mine although it is a different model #. I fixed mine by removing a small plastic basket looking thing in the middle of the stainless steel screen looking drain. Just turn it counter-clockwise and lift it out. Mine was almost completely plugged with lime build-up. There are 2 parts to this and they snap apart pretty self explanatory if you examine it. Then just scrub off lime build up with old toothbrush etc. Bail out as much of dirty water as you can and re-asemble.
Posted on Dec 10, 2008
Doesn't pump out olll the water after a cycle is complete
check drain hose for kinks,,check drain spout for connection blockage..if you cant listen for water going down drain in pump out cycles...remember most dishwasher are intentually not grounded
Aug 29, 2011 | KitchenAid Dishwashers
I have a whirlpool cabriolet top load washer. Should there be any water in the basket?
In the outer tub their will always be some water to keep the seals moist and prevent them from dry rotting
After the cycle is over their should be no visible water in the inner tub
typically the reason you would see standing water in the inner tub after cycle complete is a blockage in the drain pump
Aug 20, 2011 | Whirlpool Washing Machines
I run the cycle and there is still water on the bottom
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | Whirlpool 24 in. DP840D Free-standing...
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Oct 20, 2010 | Asko 1375 Dishwasher
Machine dot draining, not completing cycle.
check pump filter may be blocked . Pump always got water in it even when empty put towels down and if possible lean machine back wards .and always remove plug from wall before doing any repairs .
Feb 11, 2010 | Washing Machines
Spin cycle not completing
have you lost any garments in the wash lately? there may be one in your pump causing loss of power on the suction. When the machine spins out, have you noticed a marked decrease in time or just the dampness of the clothes? This is what leads me to believe this is a clog in the pump or the hoses to drains
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Water not draining
CHECK WATER PUMP, CHECK DRAIN HOSES, ANY DEBRI MY BE CLOGGING IT
Aug 19, 2009 | Dishwashers
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Feb 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
Not draining completely
always going to be some water left inside your d/w, cant pump it all out as long as its under the grate and not filling entire floor of unit i wouldnt worry, before each cycle its going to dicharge standing water anyway
Feb 23, 2008 | Admiral 18 in. DWCA500AA Free-standing...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
83 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
