Question about Samsung CLX 3160fn All-In-One Printer
Phaser 6110MFP Scan to Email Error
I have tried to setup the scan to email on this scanner and I receive a SMTP Error meesage (No Code with it)
I tried the Server name and the IP address with the same result. I checked IP address, including Gateway, DNS, etc.
I know the SMTP works as I have other email accounts using the same SMTP. I have verified the username and password again with the same result. We are able to Scan to PC thru the network along with printing from multiple PC's.
Any help would be great...
Thanks
  • fromeros Apr 27, 2009
    Exantly the same, just want to add that sometimes it works and send the email but sometimes it just give the SMTP error
faxman789
  • 297 Answers
SOURCE: Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Posted on Jan 17, 2009
  • 22 Answers
SOURCE: Is it possible to reset xerox phaser 6110mfp
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Posted on Mar 07, 2010
SOURCE: Scan to email gives server response error.
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Posted on Mar 23, 2010
SOURCE: Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Posted on Jul 13, 2010
SOURCE: How do you reset image
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to desired counter and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
Posted on Mar 01, 2011
How to scan with an olivetti d-copia 284 scanner?
You can setup scan to email or scan to folder. You use the web to configure this the easy way. Do you know the IP address of the machine? If you do, type it into your web browser address bar. The login defaults are Admin Admin (User and password are the same, don't forget the capital A). You can then setup an SMTP server for scan to email.
Sep 29, 2016 | Olivetti Office Equipment & Supplies
SMTP Scan to email problem on a Ricoh MPC2500
Ricoh scanner uses a email account to send the scan to email. That email account has the wrong password on Ricoh settings, probably someone changed the password and now needs to be updated. I hope it helps.
Apr 29, 2014 | Ricoh Office Equipment & Supplies
Error code c4-oo
This is normally an authentication error when scanning to email.
Take a look at this walkthrough, it will show you how to utilize Gmail's SMTP servers using any gmail mail account. Setup Scanning to Email on Sharp Printer using GMail SMTP Servers
Feb 17, 2014 | Sharp Mx-2610n Color Copier, Printer,...
What is network error (CE 03)
There is something not setup at all on the webpage or setup wrong on the webpage of the copier to allow you to scan to email. Need an IT guy make sure that your SMTP, DNS and reply address are correct on the webpage of the machine.
Nov 01, 2011 | Sharp AR-M455N Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
Status code 717 on scan to email
You have wrong SMTP settings and/or the server (SMTP) is down.
Dec 02, 2017 | Panasonic WORKiO DP-C262 Printer
Unable to scan to email with gmail on a Brother MFC-6490CW
Use SMTP relaying. Set up a computer with SMTP relaying. Go into the Remote Setup Program for your Brother MFC and select Setup Server. Use the IP address of that PC in the Server Settings and set Auth for SMTP to None. Worked great for me. This document can help you set it up on the relaying computer/server. http://www.lesolsoncompany.com/InstantKB20/Attachment17.aspx
Apr 01, 2009 | Brother MFC 6490CW InkJet Printer
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Scan to email
Scan to email needs an IP address or the SMTP server name and the port. Now it depends if you use an SMTP server or are you just at home? Normaly the SMTP port is 25. The SMTP server could be the one you use in your email account as well. Something like mail.upc.ie. If you dont have a SMTP server you cant set up scan to email.
Aug 29, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Samsung CLX 3160fn All-In-One Printer Logo
180 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
