Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
I have a rinnai 556wta heater in my apartment newly installed and it keeps cutting off after only minutes or an hour or so and flashing the number 53 in the center and a red flame symbol. It will not stay on and has a number of other issues. The managment of my apt complex appears hesitant to address the issue. Any suggestions on what might be wrong and what to tell them?
  • scorpiamj Feb 20, 2009
    Unfotunately the apt management mainenance has looked at it and they left it as is. So we have to turn the unit back on everytime it cuts off.
  • Danny Clark
    Danny Clark May 11, 2010
    53 is a diagnostic code.
    There should be a code index either in the owners manual or on the data sticker on the unit
    (usually the same data sticker that has the wiring schematic)
    Find out what the code is and let us know.
    It may be a "flame rollout" code or limit switch code.
    Sometimes wind can force air into the flue pipe and cause the flame to "rollout" back out of the burners and trip the rollout switch.
    If the installers did not properly vent the flue pipe it could be the cause of your failure. Find out what the failure code is first.
  • 1,420 Answers
An error code 53 is a faulty spark generator board. The unit needs to be looked at.
Posted on Feb 20, 2009
Rinnai 556 WT gas space heater flashing PF
most modern gas heaters use a code system to tell the operator what the problem is. look for a pattern in the flashing, and then compare that pattern to the literature on the inside of the heaters panel. When you have a diagnosis code, you can follow the appropriate course of action.
Nov 20, 2013 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Still looking for a surge absorber for a Rinnai energysaver 551F in Australia .Part Number DSA302M
If you have a part number you should be able to go to any plumber/gas fitter and ask them to order it through Reece/Tradelink etc.
Try ringing Rinnai direct, parts and sales is on 1300 555 545, ask for the nearest stockist.
Most Rinnai spare parts are a number begining with 9 for Australia. The code you have sounds like a Rinnai Japan part number. Might cause confusion if you try and order it.
Try this link to a 551 service manual. It has a parts list and expolded diagram. Don't worry that it's a pommy site. The heaters are the same.
http://www.rinnaiuk.com/5_Downloads/5_Warm_Air_Heater_Downloads_PDFs/05_Rinnai_551FTR_Service_Manual.pdf
Aug 18, 2010 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Code 99 flash after 5 min and then turn off
Flue block or venting disconnected. You could be getting cross contamination or the flue termination could be iced up. Check it out closely. There is also a recall from Rinnai for a retrofit kit. Contact your gas service provider with the serial number of the unit and they will tell you if yours is under the recall.
Feb 16, 2010 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Jan 24, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Stops working and flashes 53
you need to check the re=turn air filter and kmake sure that its clean/. Basically it shuts down the ignitor due to high outlet air temperature. Stay Warm!!!
Dec 26, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai 556wta gas heater keeps shutting off
Return the heater while you can, we bought 2 of these and have had the same problem with both of them. One of the units they replaced all the guts and still had to replace it. The other unit is out of warranty and I am considering just replacing it to save on repair costs which will eventually equal more than the cost of the unit. The thermostat wire is located in the back and can be stapled to the inside wall up off the floor. It was not installed properly. Good Luck!
Dec 05, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Max temperature for Rinnai 556WT restricted to 74 degrees
There is no way to restrict the setting and keep it UL approved. If you cannot get the heater above a certain setting you have either too small of a heater, too much outside air entering the apartment or the gas pressures are not great enough.
Oct 25, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
555 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
