For convergence problem although the picture has improved the yellow and blue have not convergerd is it possible I switched 1.5 and 2.2 ohm resistors or soldered them in wrong direction (color codes). Can anyone tell me the color code for those two. thanks
SOURCE: Hitachi 43FDX01B Convergence Problems
unfortunately you need at least one IC and you need to check the IC resistors it is not uncommon for them to burn out Hitachi has a convergence fix kit avail I do not know the part number off the top of my head hope this helps
SOURCE: looking for schematic of Hitachi 43FDX01B TV- 18 pin transistor
The parts that are missing are likely to be the convergence ICs. These are STK392-110 and should be available online from any electonics parts supplier. Expect a cost of around $25 each.
Dan
SOURCE: convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
