Question about NEC PlasmaSync 42MP3 42 in. Television
Nec px 42vp5
Hi, I read your notes on the power supply problem with the above model. I am having the same issue with my unit and I am wondering what part should I be changing. Can you please help. - Uma
  • 4234 Answers
SOURCE: NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
Posted on May 13, 2008
SOURCE: Remote for an NEC PX-42XR3A......
hello,
i have brand new remote for this model from nec company.........and 2nd you can buy yourself from company call this number and let them know your model they ,ll send u remote number is this 800-836-0655 original company website is this www.necdisplay.com
have great day let me know if u get it
thanks
Posted on Nov 07, 2008
  • 9 Answers
SOURCE: NEC power supply unit
I have most NEC plasma boards and know the procedure to determine which board is bad.
Posted on Nov 22, 2008
localwonder
  • 6784 Answers
SOURCE: power supply issues
hi there, i recommend replacing the entire board. once you have a short like this, the micro board itself will become useless. the thin micro circuitry has become separated within the layers, preventing a closed current transfer. its best to order a new canvas so to speak.
Posted on Mar 11, 2009
pabloloco
  • 2335 Answers
SOURCE: NEC PX-42VM3A 42" Power problem
I have read that this has been fixed with little more than a hard reset. This means just unplug your set for 10 minutes or so and let all the power seep out of the boards and capacitors, then plug it back it.
If that didn't fix it, your unit needs servicing. If you are handy here are some troubleshooting steps:
Check the fuse at Y-Sustainer pcb.
If blown do not replace. Look instead at scan converter boards. They are connected between y-sus & plugs from display (left side with face down, back open). Look for signs of 'burning' at upper and lower long boards. If any imperfections are found, replace all three boards: Y-sus, up & low scan.
If fuse was okay, check power supply for bloated capacitors (big board in middle of set).
I hope that helps.
Posted on Apr 19, 2010
Looking for a power supply for a NEC PX-42XRA4 plasma tv?
Paul, Check the attached links, not much on this power supply.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NEC TV Power Supply Board
NEC Plasma TV Repair Part Number Guide for NEC Hitachi Fujitsu Plasma...
Repair KIT Capacitors FOR NEC Plasma TV P506Y1 FOR Power Supply Ypsu J011A...
REPAIR SERVICE FOR POWER SUPPLY BOARD OF NEC 50XP10 50 PLASMA TV
Mar 08, 2016 | NEC Televison & Video
NEC MODEL PXT-42S11S has no sound HELP!!!
What you describe is a symptom of power supply failure in flat panel TVs
Apr 03, 2013 | NEC PX-42VP4PA 42 in. EDTV-Ready Plasma...
Power issue NEC PX-42VM5A
Most likely a transistor - NEC used FSM series for a while which are now discontinued. Let me know if you need info on how to find/tell which parts are bad.
Jun 22, 2009 | Emerson LC320EM8 32 in. LCD TV
NEC PX-60XM5A 8 Blinks
Overheating issue. Check your power supply board.
May 23, 2009 | NEC PlasmaSync PX-50M5A 50 in. Television
Power supply issues
Mar 11, 2009 | NEC PX-42VP4PA 42 in. EDTV-Ready Plasma...
Monitor turns off by itself
It is a power supply issue. Check this thread:
http://www.fixya.com/support/t782900-nec_px_42vp4da_stay
Feb 16, 2009 | NEC 42 in. EDTV-Ready Plasma TV
Aug 26, 2008 | NEC PlasmaSync 50MP1 50 in. Television
NEC PX-42VP4DA- Won't stay on
Yeah, it's the power supply.  I've ordered (2) of these power supplies used, and the same problem seems to be happening with both.  The transformers on the power supply board (namely, the 170+ volt one) are the problem. You have several test points on the power supply board which you can touch with a voltmeter to see if your television is getting the correct voltage .  Mine made a a high pitch squeal which indicated which transformer was bad. If you find a place to get the transformers new - id like to know, because mine is still non functional because of this and the fact that a new PS board is over $600.
Jul 14, 2008 | NEC PlasmaSync 42MP1 42 in. Television
Power lite blinks red and will not turn on
Sounds to me like you're experiencing an issue with the power supply in the unit.
Nov 21, 2007 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
Nec px 42vp5
The fault is on the PSU board.
Replace D 28 on the PSU board. You have to use a fast diode (I used BYW 95). Replace also the
330 uF/35V and the 22uF/50V near to this diode.
After this the unit will work perfect.
Oct 25, 2007 | Televison & Video
NEC PlasmaSync 42MP3 42 in. Television Logo
47 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
