Question about Tappan 30IN ELEC IGNa Oven
Digital clock display
I can't keep the clock displayed on our electric stove. It keeps changing to 000
    Sergeant:
    Champion:
  • 324 Answers
Stuck keypad or bad clock may come as an assembly.
Posted on Dec 06, 2008
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Power failure,now 000 is flashing on oven exterior
If the 000 is on the display left of centre, then you possibly just need to reset the clock. from left to right-....press the first button to activate the clock setting phase....press the next button to pop out the rotating timer adjust and set the time.
If it is the display above the centre control dial pls repost with the full Enr from the rating plate.
Feb 25, 2013 | Neff B1881 Single circotherm super...
Digital display is not working
you need to check the main power and see if the power is orrect if so replace the electronic control better known as the clock timer
Jul 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
Maytag wall over MEW5530BCB
Usually this turns out to be a problem with the main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru ----- www.repairclinic.com
http://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 26, 2009 | Maytag 30" Built-In Single Electric Wall...
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Stove with LED clock display, need to be set
Try holding 2 buttons at a time and whilst doing so, press the button with time on it or clock face, or just keep trying different buttons until myou get the right combination, stick with it you will get it to go.
Dec 15, 2008 | Stoves Ovens
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Tappan 30IN ELEC IGNa Oven Logo
137 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
