Question about Kenmore 65924 Electric Dryer
Kenmore 80 electric dryer fan mounting
How do I remove the fan from the motor shaft?
  • johfraser Dec 05, 2008
    Thanks. I am familiar with steering wheel pullers. However, the motor shaft is not visible in the center of the fan so there is nothing for the puller to push against. The fan is like a cap that goes over the end of the motor shaft. I think it may screw on but I can not budge it.
  • maledeer Feb 18, 2009
    trying to remove a motor out of a kenmore dryer but cant get the fan off
  • 334 Answers
You need a blade puller.
It is a tool that grips the fan blade from behind, and as you turn the screw that sits at the end of the shaft it pulls the fan off the shaft.
Never hit the end of the shaft with a hammer, as it can mushroom the shaft end, an prevent the fan from coming off.
You can get a puller from most HVAC supply houses, and sometimes at Hardware stores.
Its similar to a steering wheel puller.
Posted on Dec 05, 2008
  • Danny Clark
    Danny Clark Dec 06, 2008
    Is there an allen wrench screw? Is the shaft whole round or does it have a flat spot?
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Nov 16, 2014 | Bosch Dryers
How to remove fan from back side of 80 series dryer so motor can be removed?
Hello John Bailey,
I believe if you look very closely... you will
see a splined (bronze) center bushing in the center
of the squirrel cage fan: Check for REVERSE threads.
A little penetrating oil and some FIRM pressure
should be sufficient to get the fan moving...
Force nothing ...
To get the ACTUAL cost of the FAN if you
BREAK it... you will need a COMPLETE model number...!!
Then go to... ( I don't recommend SEARS)
Search Over 2 1 Million Appliance Parts
Or shop on eBay for VERY competitive prices.
Hope this helps
Carnac the Magnificent
Dec 15, 2017 | Kenmore Dryers
HE3 fan replacement
1 Pull the plug for the Kenmore dryer out from the electrical socket. Move the Kenmore dryer away from the walls or any obstructions behind so that you can work on it safely.
2 Remove the lower front panel from the Kenmore dryer. These are usually secured with screws at the sides. Once the panel is removed, locate the blower, which is a circular shaped object connected by a belt to the Kenmore motor. If you cannot locate the blower, then it is mounted on the back of the machine.
3 Remove the rear service panel by loosening the screws holding it in place. Pull the panel aside.
4 Loosen and remove the fan blower belt. Locate the tension pulley in between the motor and the blower. Pull the tensioner back to relieve the tension on the belt. Remove the belt by pulling it off the motor and the blower.
5 Grasp the blower with one hand. Use a socket wrench and socket to loosen the blower bolt holding it in place. If the bolt is stubborn, spray it with some penetrating lubricant and allow this to soak in for a few minutes before trying again.
6 Pull the blower off the blower shaft.
Also look up this video
Apr 16, 2012 | Kenmore Dryers
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
adjustable wrench
locking pliers
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Apr 22, 2010 | Kenmore 62602 Electric Dryer
How do you get the motor off of a whirlpool dryer? We are trying to replace the bulkhead, but can't get the motor and blower separated
The blower will be held to the motor shaft by one or two allen set screws. Loosen these screws and the motor will pull out. the blower fan will drop down so make sure you can somehow hold it while you pull the motor away. Obviously unbolt the motor from the chasis.
Hope that helps.
Jan 16, 2010 | Whirlpool LER6611L Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Belt tension part. it fell off and i need to know where it goes on the dryer. Kenmore 80 series gas dryer.
The bracket goes into holes on the floor beneath the motor pulley and looks like the picture of whirlpool in the link below when properly mounted:
Oct 29, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 65924 Electric Dryer Logo
215 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
