Question about Garden
Hi, i have an old 1982 victa 11hp all steel 38" cut ride on. the problem???? the cog at the bottom of the steering column is very lose, therefore am unable to turn left. there is no purchase there. do i have to pull the motor out to get to it or is there a better and easier way?. thanks
  • 211 Answers
You have to remove the engine and check the cog(better way).
regards savumihai71
Posted on Dec 09, 2008
How to put a 1982 chevy truck steering column back together
Jan 28, 2011 | 1982 Chevrolet G20
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
How do you remove a 1987 Ford Econoline ignition switch assembly
1982-88 Models Fig. 4: Align the flexible coupling to specifications (shown)--1982-88 models 89788g36.gif
Fig. 5: Exploded view of the steering column--1982-88 models 89788g41.gif
  1. Set the parking brake.
  2. Disconnect the battery ground cable.
  3. Disconnect the flexible coupling from the steering shaft flange.
  4. Disconnect the shift linkage rod(s) from the column.
  5. Remove the steering wheel. NOTE: If you have a tilt column, the steering wheel MUST be in the full UP position when it is removed.
  6. Remove the floor cover screws at the base of the column.
  7. Remove the steering column shroud by loosening the bottom screw and placing the shift lever in the No.1 position (on automatics) and pulling the shroud up and away from the column.
  8. Remove the instrument cluster column opening cover.
  9. Remove the 2 bolts securing the column support bracket to the pedal support bracket.
  10. Disconnect the turn signal/hazard warning harness and the ignition switch harness.
  11. Lift the column from the truck. To install:
  12. Position the column in the van.
  13. Connect the wiring.
  14. Insert the column through the floor so that the flange engages the flexible coupling, then, raise the column and loosely install the bracket bolts.
  15. Loosely install the flexible coupling nuts and floor plate screws.
  16. Install the steering wheel.
  17. Adjust the steering column as follows:
    1. Tighten the flexible coupling nuts to 35 ft. lbs. (47 Nm).
    2. Place the wheels in the straight-ahead position.
    3. Verify the safety pin-to-flange cut-out clearance of 0.160 in. with a feeler gauge.
    4. If necessary, loosen the flange nuts to adjust the clearance, then retighten the nuts when clearance is established.
    5. Tighten the column support bracket bolts to 20 ft. lbs. (27 Nm).
    6. Tighten the cover plate screws to 10 ft. lbs. (13.6 Nm).
    7. Tighten the lower clamp bolt to 10 ft. lbs. (13.6 Nm).
Jul 08, 2010 | Ford E-350 Cars & Trucks
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Check and service diff lube on ride on a victa lawn mower
You have to disassemble the diff if you want to clean out the old grease, But another way is to put a grease nipple on it. There are two types of grease used in these they are: Bentonite grease & graphite grease.
Jul 25, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Describe your Poulan 38-Inch Steel Deck 15.5 HP
Go to this site:
Download the manual and it gives a good clear picture of how the belt is supposed to go on.
Jul 17, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
