Question about RCA TH1101 MP3 Player
My recorder/plaer is frozen in the on position,
The recorder was used earlier. when reaching home, I found the light panel on and the voice selection highlighted, but none of the keys will work. The entire system is frozen in the on mode.
  • 8,596 Answers
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position.If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
If this does not work, reset the player by removing/reinserting the battery.
Posted on Jan 09, 2009
How do I get my computer to recognize Radio Shack FMS 43-127 voice recorder?
HAd the same problem. In the file manager software click "USB" from the top menu bar and then "connect to recorder." It found it after that. Good luck!
Jun 26, 2013 | Radio Shack TRC300 Voice Recorder
I am having smsung sgh-L700. its not having the feature of recording voice calls . i want to know whether we can do that using some software.
Try recording with the inbuilt voice recorder.To access voice recorder go to main menu and reach the inbuilt voice recorder
Dec 02, 2009 | Samsung SGH-L700 Cell Phone
I have just purchased Logitech QuickCam E3100 - is there a microphone in this or do I need to purchase a seperate microphone or replace for a combined Web Cam and microphone?
Get a separate microphone, do not get a combo. This way you can position your camera at an ideal position and your mic as a perfect position to pick up your voice. combo units are nice because its one less thing but you will be unhappy with the results
Oct 04, 2009 | Logitech Webcam
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Microtrack screen is on and frozen
I was able to clear the same issue by removing the CF memory and erasing it using a USB card reader connected to my PC. I erased all the files and reinstalled the card in the Microtrack. Works fine now, must have been a corrupted file even though it only contained two mp3s I had recorded earlier.
Dec 19, 2008 | M-Audio MicroTrack 24/96
I have a sandisk sansa m240 mp3 player i found but the screen is busted. I figured out how to do everything without the need of seeing what was on the screen, except how to record stuff.
This will probably be impossible without a screen, but here are the steps:
The Sansa Fuze has a built-in microphone allowing you to record your own voice, an
interview, or a speech.
To start voice recording, follow these steps:
1. Press the Home button to return to Main Menu.
2. Select Voice from the Main Menu.
3. Select Record Now.
4. To pause the recording, select Pause.
5. To stop the recording, select Stop.
6. Select Yes to save the recording.
7. Press the |<< button to return to the previous menu.
Dec 03, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk Sansa M240 Screen Busted
Hard w/o screen, here are the steps:
Voice Editing 1.0 premium Update for Vista
Try this
Uninstall the software.
Reinstall the software
After installing the software update from Panasonic, plug your recorder into the computer. Go into 'Control Panel' and select 'Hardware and Sound'. Then Select 'Device Manager' and select 'Universal Serial Bus controllers'. You should have a device for 'Panasonic IC Recorder', it might be flagged yellow, right click on it and select 'uninstall'. Unplug your recorder from the computer, replug your recorder into the computer, the Device Manager screen will refresh and you should have 'Panasonic IC Recorder' back in the list. Try the Voice software, you should have in the drive list 'IC recorder'. Transfer your files.
It worked for me,
Pierre
Jul 27, 2008 | Panasonic RR-US500
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
PD-6030 MP3 Voice recording distortion
MyMusix's PD-6030:
Manual can be found at www.mymusix.com
EQ setting
Select from "Normal, Rock, Jazz, Pop, Classic, Bass" .
You can also select "Exit" to keep the original settings.
Menu Tree Diagram is on p.29
For "password" question - there is no password, the lock on the player has simply been engaged - slide it to the unlocked position. See manual for details.
-Tha Mp3 Doctor
Nov 05, 2007 | MyMusix PD-6030 MP3 Player
RCA TH1101 MP3 Player Logo
27 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
