Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
RUST ON STAINLESS STEEL
MAYTAG DIISHWASHER dwu8330aax Serial # A1480272HF CAUSING RUST ON STAINLESS STEEL CUTLERY AND FLATWARE.
    Scholar:
  • 145 Answers
Debruce Polish works great stainless steel removing rust, also use on ceramic cook tops, polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
What is the role of stainless steel products?
Products which are manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do. On the other hand, if it is hardened stainless like what is used in instruments, you probably will need carbide, although you might get a tool steel drill to make one hole.
Stainless steel is defined as a steel alloy with a minimum of 11.5 wt% chromium content. Stainless steel does not stain, corrode or rust as easily as ordinary steel, but it is not stain-proof. It is also called corrosion resistant steel when the alloy type and grade are not detailed, particularly in the aviation industry. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Common uses of stainless steel are cutlery and watch straps.
For detailed information visit at: Solutions of Stainless Steel Products
Feb 01, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
What is the difference between mild steel and stainless steel? Which is more stronger?
Stainless steel is stronger. It has a mix of other metals like chromium and vanadium which makes it stainless and generally more rustproof.
Mild steel is cheaper and is also known as high carbon steel. This is a softer steel and rusts very easily.
Jan 04, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
Is it more expensive to buy stainless steel or silver silverware/flatware?
Silver is more expensive than stainless steel. Silverware pricing is high as silver is a precious metal and silverware is considered to be an heirloom. So if price is not a problem for you then silverware is the way to go. But if you want some thing more cost-effective, then choose stainless steel.
Read more at Buzzle: http://www.buzzle.com/articles/stainless-steel-flatware-vs-silverware.html
May 06, 2013 | Home
What is flatware? i've never heard this term.
flatware is cutlery. it's a term used in the US. if youre shopping online for cutlery and its an american store, you have to look for it under flatware.
Jan 14, 2013 | Home
The door is getting rusty. I believed that stainless steal didn't rust. Is there a way I can remove the spots?
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to this site.
Mar 22, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Rust spots on cutlerey
Rust spots on cutlery, but not on other dishes? It may be the blades are high carbon steel and not stainless. If so, then wash them by hand and dry with a towel.
Sep 06, 2009 | Washing Machines
S/s cutlery comes out with rust spots, why?
Only two possible reasons. In order of likelyhood:
1. Cheap Cutlery.
a) There are various types/grades of 'stainless' steel, some of which simply are not.
b) May be just lightly coated/plated steel
2. Excessive iron in your water, which would be showing up in your toilet tanks more than anywhere else. In which case, you need a softener with a chemical feed to address the iron and/or a dedicated iron filter.
Aug 08, 2009 | Dishwashers
Aplliance fronts in stainless steel
I'm not sure about some of those appliances but ApplianceArt.com maybe able to help you. They sell stainless panels as well as the Softmetal adhesive stainless that's been on HGTV's "I Want that," "Design on a Dime," and "Real Estate Intervention." And I think some others.
May 08, 2009 | Maytag MMV4205 Microwave Oven
Cloudy glassware, stained flatware
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 19, 2009 | Maytag 24 in. DWB1000 Built-in Dishwasher
Maytag MZD2766GES Side by Side Refrigerator
Not actual stainless steel or the magnets wouldn't stick then all those frige magnet companies would go out of business. Maytag should make a cleaner/protector spray or something that will clean that up. Even the DIY stores like Home Depot or Lowes, etc. should have that type of cleaner. Naval Jelly can work but test in on a spot that won't show in case it stains the finish more than helps remove the rust. And yes, that would be cosmetic issue not a warranty item usually BUT read the extended warranty yourself to see if there is a loophole!
Oct 30, 2006 | Maytag MZD2766GES Side by Side...
Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
182 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
