FixYa.com
Tags:
Danby DDR401 Dehumidifier
Compresser runs, no water is removed
posted by scaurex on Feb 10, 2007
If I turn on the dehumidifier, the compressor starts running as normal, but no water is collected in the bin. I've run the unit for hours on the lowest setting(the --) and not a drop.
I took the back off it to see what is happening. The compressor (large black pot) gets very cold and the condensation is running off it.
I must admit I may have "abused" it. I was using it to dehumidify my RV last year and the temp did get down close to freezing. Not sure if it is damaged by low temps or not. It also rode in the RV for a few hundred miles, so it's been shaken a bit.
BUT it did work once or twice properly after this.
Is it something I can fix myself, or does it need to go for service?
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Dehumidifiers problems?
danby humidifier
Red light comes on when pluged... Answer This...
danby dehumidifier sdr458h
My dehumidifier display is... Answer This...
fan inoperative
the blower motor doesn't come... Answer This...
Beeping full signal
Is there a way to turn the... Answer This...
danby dehumidifier E3 flashing...
I took it appart and found the... Answer This...
Repair Service
Find Dehumidifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
