Question about Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black
My pioneer inno2 don't sent any fm signal to the car stereo
I can't listen any music thrue the radio in my car, I have the same FM frequency in the inno2 and the stereo in my car but I can't listen nothing, Is not the car radio because I try another Inno2 that I have in my other car and that one work great, I changed the car kit and either work, I try it in another car and only hear the music but very very low and bad signal, everything is hook-up right and I would like to know witch is the problem and how fix it. I will apreciate who could help me. I have the same problem!
  • mgross41 Dec 07, 2008
    I have this inno radio hooked up in a car that works fine with another inno radio. I did this to eliminate the car stereo, car cradle and antenna as problems (or so I thought). I did this when the radio didn't work in the new car I was going to use this in. Radio picks up xm when not connected to the car but nothing comes through car stereo when in the cradle even on multiple frequencies.
    Added sure connect to the other car and it solved the problem-don't know why it wasn't needed with the one receiver but that fixed the problem!
    Genius:
  • 1,239 Answers
HI
You may have an intermittent switch or possibly a shorted or broken wire. As for the radio, I'd yank it and put an after market deck in. GM radios aren't known for their quality. But, you could check the back of the radio to see if the antenna lead is plugged in securely.
Hope this helps.
Posted on Dec 07, 2008
    Sergeant:
    Champion:
  • 201 Answers
Make sure you dont have a frequancy clash to this could blank one transmitter out hopes this help, change your freq on the transmitter tune yur tuner to see..
    Genius:
  • 1,847 Answers
Seem issue with the antenna cable. let me check for more updates.
Posted on Dec 05, 2008
  • Legin Varghese
    Legin Varghese Dec 05, 2008
    It seem antennae has a fault or the antennae cabling has an issue.
    Try these..
    1. First check to make sure the antenna at the back of the radio has not come loose.
    2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
    3. Peel back the carpet on the front seat passenger floor.
    4. Locate the coax antenna cable running along the side.
    5. Reconnect the two pieces of antenna that have come loose.
    6. Roll the carpet back, and re-install the threshold cover.
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Only in certain areas and passing vehicals cause interferance
I'm assuming your using a RF unit (radio frequency). Whether this unit inserts in the antennea line or is simply broadcasting an FM signal via it's own antennea, it is still transmitting a low power FM signal. The idea here is to find an unused FM channel in your area, set your radio to that channel and program the Sony RF unit to use that channel. The signal the Sony RF unit is transmitting is low power due to FCC regulations and to minimize the possible interference you could cause to someone else's FM listening.
You are likely using an FM channel that is being overpowered by a real FM radio station. This is usually solveable if you only travel in your town by picking an empty FM channel. If you travel alot, the channel in your town that is empty may not be the case when you travel 50 miles away. That's just part of the problem inherent when using radio frequencies to get your music into your radio. You have to be willing to deal with it.
As far as passing vehicles, I'm going to assume that the vehicles that are interfering with your radio are doing the same thing you are doing, they are using FM radio frequencies to pump music into their radios and they are using an FM frequency close to or the same as the one you are using. Since having an unused channel on the FM band is pretty rare these days, if there is one, you can bet everyone is trying to use it for their own purposes since it is "quiet", until you come around!
Aug 07, 2009 | Sony CDX-454RF 10-Disc CD Changer
How to hookup an IPOD to a pioneer avh-p6500 car stereo
If your car stero has a stereo audio input connector then you can plug a cable in the headphone on the IPod and the other end of the cable into the stereo audio input on the car stereo.
If you don't have an stereo input on the car stereo then you can buy a FM transmitter that is powered by the car's cigarette socket, connect the IPod to the transmitter, switch on the car radio and tune it to the FM station that matches the FM transmitter.
You can now listen to your IPod from the car radio.
Jan 26, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
I had to add the sure connect antenna on one vehicle and it solved it. Doesn't make sense since one car would run one receiver and had no sure connect but the one receiver needed it. Anyway-works for me fine now!
Nov 23, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer inno
Have to use a car dock to use the fm transmitter.
Sep 29, 2008 | Pioneer inno2 Portable XM Satellite Radio...
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black Logo
156 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
