Question about Casio Exilim Card EX-S600 Digital Camera
Charging battery the battery died when in use and when we placed it on the charger the red light flashes instead of staying solid red and does not charge the camera. Other functions on the cradle work. I tried removing and reinsertting the battery and checked the contacts and they are clean. the contacts on the charger are also clean. I down loaded the pictures on it thru the cradle so that seems to be working
  • Anonymous Dec 15, 2007
    i have the same problem,flashing red light on the docking station.i left it over night on charge but still no joy. does this mean i need a new battery!
  • 4 Answers
Okay, the same thing happened to me. I ordered a new battery and that was not the problem since the same blinking light was haunting me! So I bought a wall charger for the battery alone and then it worked again on the original docking station. Apparently it will not recognize a completely dead battery on the docking station. It makes no sense but it worked for me. So good luck to you!
Posted on Aug 25, 2007
  • 374 Answers
BAD BATTERY. if it is less than one year old they will replace the battery for you. Contact tech support and give them your contact information. They will require you send in your battery and give you the address to send it to. Then they may be able to send you a replacement free of charge.
Posted on Jul 08, 2007
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
Should the red light on the battery charger stay on, even when the battery is charged? Or does the continuous red light mean the battery will not charge?
I am not familiar with this model, but most chargers have a flashing light as the battery charges, and a solid light when it is charged. Do you have the manual? It should tell you what the lights mean.
Jul 17, 2010 | Powerglide Power Glide Cordless Drill
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Cant charge my battery
i have same camera.. but i dont think this is a problem.. while charging light keep flash.. when it completes charging it shows u solid red light..
Dec 25, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Casio Exilim Card EX-S600 Digital Camera Logo
94 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
