Question about LG DU-62SY20D 62" Rear Projection HDTV
Color fading my tv started to lose color since yesterday and i'd been trying to fix it plugging and unpluging the tv but seems like the problem is major
  • sd_794 May 10, 2009
    ITS SONY TV 52"  8 YEARS OLD GETS COLOR FADED IN BLUE COLORS AFTER 4 TO 5 HOURS CONTINOUS WATCHING TV.
    Problem Solver:
  • 15 Answers
Maybe the filters are dirty,
Posted on Jan 28, 2009
My Samsung TXS3082WH 30 inc wide screen TV seems to be losing color and going in and out and i notice when you watch cartoons its fine but when it goes to actual shows or channels with normal footage it...
There have been a lot of problems with the Samsung sets, one dealer I know had so many complaints about the ones he sold he stopped selling them and switch to another brand and he has been trouble free ever since. To answer your question they have problems with the screens, color texture, lines, fade out to name a few, from what you have described you have at least two or three issues, considering the history I would replace it.
Jan 07, 2011 | Samsung SlimFit TX-S3082WH 30" TV
Have a Sony KP53S65 Rear Projection TV... while watching, it made a pop sound... the picture shrank (faded) to a small circle of color in the middle of the screen and than disappeared to nothing. There...
The tv have blown electronic components Highvlotage deflection circuitries area.This tv is not an easy fix,must hire a tv Tech.get an estamate to troubleshoot and replace components,sorry could be anythings,if it just pop and fade picture away.Well LCD tv is pretty cheap these days,compare prices a new LCD tv or fix up the old DLP tv u determine.The cosmatic appearance,mean nothing in electronics devices.
Dec 30, 2010 | Televison & Video
My monitors colors are fading cant read any white writing, not the first time this has happened, it will fix it self to perfect color then all of a suden lose reds and oranges, and fade colors
This is highly likely that a capacitor in the power supply is failing, a lot of people are having problems with them going bad. Samsung, reportedly, will fix it for $545 or thereabouts, but people are replacing the 4 1000uf caps in the power supply themselves, for $30. I've never done it myself, but they say after you get the back off, they're on the power supply board in the middle. Some people have replaced the whole board for $100 when they can get the boards, apparantly some are on backorder. The problem, of course, could be in other parts of the tv's circuits, but this seems to be a prevalent problem with Samsung. Hope this helps.
Mar 12, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Arc or hump on bottom left of tv and color is faded bad.
Your convergence Ic's have gone bad. Most likely a few small resistors with them. It's really not a job you should try and takle if you haven't done it before. Not a major deal for a svc co.
Feb 05, 2009 | Philips 60PP9202 60" Rear Projection...
Magnavox TV/DVR/VCR Combo Model 20MC4304/17 color out
tengo un televisor magnavox combo pero so;o quiero sabersi se puedde dejar solo funcionando como tv ...y eliminar dvd . ya que no puedo hacerlo.
alguna ayuda se la agradeceria
Feb 03, 2009 | Philips Magnavox 20MC4304 20 in....
Fading and losing pictures
If your TV has more then 1500-2000 hours of usage chances are the power board is starting to fail due to the amount of heat that the parts are expose to when the TV is on. There seems to be a high failure rate on power supplies due to overheating.
The solution to get the TV working properly will be to have a new power board or repair the on inside your TV.
Let me know if you require further assistance.
Jul 26, 2008 | iLO 3200 32 in. LCD Television
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Color problem
Samsung color wheel fix
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Picture Fades
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Jul 12, 2006 | Sony KP-57WS500 57" Rear Projection...
LG DU-62SY20D 62" Rear Projection HDTV Logo
179 people viewed this question
Computer Repairing
Computer Repairing
