Question about JVC AM FM CD DET FACE CAR STEREO
JVC Car stereo with cd shuts off when volume is turned up
Just wondering if you have any thoughts on this problem. The stereo is wired properly, it just shuts off when the volume is turned up, sometimes as early as 17, then it comes back on, and if you turn it down it plays, if you don't it shuts back off.
My son thinks it's the speakers, what do you think? Will new speakers help? It's installed in a 1994 Nissan Altima.
Thanks for your help
  • t66ls Dec 07, 2008
    Thank you tooldoc, I looked at the owners manual and it has a maximum volume of 50. The owners manual also say that it has an audio amplifier max power output: front 45 watts per channel, rear 45 also, Continuous power output (RMS): front 17 watts per channel into 4 (then it has some symbol that looks like a fancy upside down U) 40 HZ to 20000 Hz at no more than 0.8% total harmonic distortion, it goes on to list other specifications.
    Sorry about my slow response I didn't realize someone had responded. I can tell you my brother in law installed this several years ago and it didn't shut off at high volume then. I am just guessing it's the stereo not the speakers, and I don't want to buy new speakers and find out that wasn't the problem. I'm the mom as you probably have gathered and don't know much about this stuff. I will pass on the information you provided to my son and we can start checking into the amp.
    Thank you for your time and help with this matter.
  • t66ls Dec 12, 2008
    Thank you, you were right on the money. We bought a new receiver and installed it and the speakers don't shut off.
    Thanks for your help.
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Posted on Dec 05, 2008
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
I connect my car stereo and the speakers don't work
Not to be rude but is the volume turned down or mute on? Take the deck out and check all your speaker wiring. I would use screw ons for proper wires being terminated together.
Sep 20, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
I have a car cd player jvc kd-g321 i cannot turn it on to use my cd`s
You need to connect 3 wires properly one is power 12v,ac, snd acc,ignition,and Trd remote.
Jan 04, 2010 | JVC AM FM CD DET FACE CAR STEREO
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Aug 11, 2008 | JVC AM FM CD DET FACE CAR STEREO
Jvc
will have a another look around for you but you could start here
http://4jvc.co.uk/cgi-bin/pne.pl?display=entry&brand_id=2158&f-10=%20JVC%20KW-S601%20car%20stereo
see if they can assit as well , i i find one i will post back for you, good luck .
riz.
Nov 20, 2007 | Car Audio & Video
JVC KD-G720 car stereo - how to change the time?
Press and hold the SEL button to bring up the settings menu. Press and release the tuning (>>>) buttons until you see CLOCK H. Turn the volume knob to select the hour. If necessary, press (>>>) for CLOCK M; adjust the minutes setting with the volume knob. Press SEL when you're finished. An owner's manual can be downloaded from JVC at this link: http://books.jvcservice.com/booklist.asp?Model=KD-G720J
Mar 15, 2007 | JVC KD-G720 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
2,218 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
