Question about Dell 3000cn Laser Printer
I have a Dell 3000cn printer. It is starting to have a white stripe on right edge of paper on all print jobs. I replaced the toners but still have the problem.
I had this same problem, after looking on the Dell website it was quickly fixable by using the 'cleaning rod': http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=67F5968241CB3237E040AE0AB6E16159&treeid=D6DBAD7A5D093D52E030A68F2728742F&Query=&SystemID=PRN_LSR_3000CN&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
check the second box that says there is no error message, and it leads to instructions for what to do. Hope that helps.
Posted on Apr 21, 2009
  • 73 Answers
It sounds like the drum is starting to go. The drums have a life cycle of about 30000 pages, but they also wear out over time. You can purchase them directly from dell by calling 8002893355 (US).
Posted on Feb 08, 2009
I have a Dell 3000cn printer it is saying load paper but the paper is loaded but wont print
check whether the cartage is fix well or the paper is far from the area from where the printer starts printing.
Jan 27, 2011 | Dell 3000cn Laser Printer
An Empty Stripe along the right side of portrait setting
Have you tried a new toner cartridge? There is a couple possible culprits.
Thanks,
Lee
Jul 19, 2008 | Dell 3000cn Laser Printer
Right hand edge doesn't print
generally a failure of the imaging drum. Like most moving parts they wear out and need replacement.
Jan 25, 2011 | Dell 3000cn Laser Printer
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
Printer leaves a grey haze on the page.
If your fuser is not failing then someone probably didn't install the toner properly. Regardless, it is incredibly hard to clean toner out from all the guts and the gray won't go away as long as it is there. I would take it outside, wear a smock, and blow it out with an air compressor or half a dozen cans of compressed air. Wipe down and clean every part you can.
Replace the toner cartridge. Then run a couple dozen copies of something to pick up the remaining toner from the internal mechanisms. See if their is any more toner. If there isn't...then somebody messed up and you just need to work the last of the toner out of the innards.If there is more toner after you clean it out and replace the toner cartridge, start thinking about replacing the fuser.
Oct 02, 2009 | Dell 3000cn Laser Printer
My Dell 3000CN is out of yellow toner
located in your control center for the dell printer is an option to print in black and white onlhy. click that u should be able to print.:)
Sep 07, 2009 | Dell 3000cn Color Laser Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Ink dots on right side of paper
Toner cartridge? So this is a laser printer? In that case I suspect it is not new? This sounds like old age on the main image drum, that will probably give the exact same mark on each page, correct?
Apr 15, 2009 | Dell 3000cn Laser Printer
Replaced Toner- It Still Won't Work
it is possible that it is not installed correctly, ensure that it fits rightly on its place, oterhwise there is no way it would resume printing, reset the unit once again open and close the covers and turn the switch on and off to reset
Aug 08, 2008 | Dell 3000cn Laser Printer
Paper feed wheel
sounds like something was not put back in right and something is not making good contact.
Dec 07, 2007 | Dell 3000cn Laser Printer
Dell 3000cn Laser Printer Logo
455 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
