Reset printer HP PSC1402
I use this printer with a Windows XP machine.
This was never a problem.
After chancing the cartridges last time, it happened.
Or better......it didn't happen.
Now the inkt lite is flashing en it won't work.
Is there some way to give a hard reset???
Resetting the HP All-in-One can sometimes resolve basic issues with the product's functionality, such as when there is no response from any one of these HP PSC products1400 series - 1401, 1402, 1403, 1406, 1408, 1410, 1410v, 1410xi, 1415, 14171500 series - 1503, 1504, 1508, 1510, 1510s, 1510v, 1510xi, 1513, 1513s, 1514. Reset the HP All-in-OneFollow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button.
Posted on Mar 09, 2010
HP CP1215 reports toner cartridges nearly empy after less than 30 pages of light use.
Please check the cartridge page yield before procuring it. Check the cartridge part number last digit, if it is suffix with "A" it will only last 1400 page yield, if it is lasting with "AD" it will last up-to 2000 page yield. Also double check the toner cartridge is originally made by HP. No chance for logic fault.
Feb 17, 2012 | HP cp1700 Color Inkjet Printer
Reset hp 920 ink cartridge
you can reset the hp 940 cartridge very easily by following these steps as under.. 1.. just take and insert the cartridges in the cartridge holders gently and softly until you hear the clicking sound 2.. just reset your printer and then start the recycling process so that the printer refreshes the cartridges. 3. Press the OK button on the printer and hold it for 5 to 6 seconds, and at the same time when you are holding the OK button press the red stop button also while holding it till the LCD gets refreshed
thanks
Dec 11, 2010 | HP Officejet 6500 Wireless All-in-One...
My xp shows a device10 notification window on most shut-downs of my computer. I press the x in the upper right corner and I can shut-down. Right now it's just annoying. I have HP Officejet J4580 All-in...
Device 10 notification likely a printer related issue. Lots of odd things can happen when HP cartridges are empty. With some HP printers, they will not run with one etimpty cartridge. There is a work around in that instance. You can "fool" an HP into thinking the cartridge is full. Of course, you would want your HP to be set to use only the black ink, for otherwise, it might try to mix a batch of black ink using other colors (and your other tank would be empty!) Now, if you are not of a mind to buy the color cartridge, you can explore the trick of fooling the HP. There is a chance that this would eliminate your device 10 notification, simply because you tell me nothing else is different. No promises, but I would have to try it. Now, just what other effect the trick might have over time is a caution. Nothing is cleaning those other nozzels. At least your HP is still working as is.
Jun 09, 2017 | Microsoft Windows XP Home Edition
All lights flashing on HP psc 1350 printer
Resetting a Hp printer means switching off the machine, removing the cartridges, disconnecting the usb cable and the power chord, leave it off for few minutes then restarting it again without usb cable connected to it and without cartridges installed. You need to press the power button while it boots up. Leave it one for few minutes and again turn it off. Reinstall the cartridges and plug in the usb cable, again Power On the printer. That's all.
But there's another thing when you say all lights are blinking/flashing, there is chance that there's an internal faulty. Clean the cartridges contact point and the contact points on the printer. If possible, clean the printer thoroughly, including the waste ink tank. This will let you help find out the culprit.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
Hp j6450 all lights flashing will not reset! attempted to reset the machine. it is only used on a fax/copier
how do I reset the error message reading remove cartridge on the right , On the HP o FFICEJET 7310XI All- in - one ????
Jan 29, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hp 3920 deskjet printer
Please check for the cartridges and try to make copies.
Aug 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Ink Cartridge shown empty on HP 7780
How did you do the factory reset?
Take out all cartridges and heads then unplug for 30 minutes?
Plug back in and reseat all removed items?
If so you probably have a bad head.
You can order them through HP or Staples.
The heads have a very short life of 10,000 pages.
Jul 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Ink Cartridge won't reseat
When you put a new refill in an inkjet printer, the brain of the printer sends a small electric charge to the cartridge. Try going into the menu of the printer and check or click on the instalation of a "new" cartridge. It will send the charge to the ink and that may be the problem. If that dosen't do it, then see if you can reset the machine by disconnecting the power and any cables for a minute, and retry it then
May 14, 2009 | HP DesignJet 5500PS InkJet Printer
HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Jan 29, 2009 | Office Equipment & Supplies
Page count unreasonable
Re you using genuine HP NEW cartridges? If not, you must make sure that whoever has re manufactured the ones you are using has replaced the chip on the cartridge. This tells the machine how many copies are on the cartridge.
Nov 14, 2007 | HP LaserJet 2550L Printer
2,395 people viewed this question
k24674
jasbo
jasbo
