Question about HP PhotoSmart C4480 All-in-One Printer InkJet
My scanner won't work. When I push the Scan/Reprint button and tell it to scan to the computer, it says it is scanning for a little while and then says "Scan error. Try scan from computer or see documentation." The software installed on the computer is the C4400 series. I can't find anything referring to the scanner and don't have any idea what is wrong.
  • 2 more comments
  • withlime Dec 07, 2008
    I'm having the exact same problem! I don't know how to fix it :(
  • Anonymous Dec 17, 2008
    I have the same issue and I know the scanner is working because if you scan to print, then it will scan the document and print it out. So the scanner itself doesn't seem to be broken.
    I'm running Windows Vista Home Basic, and I'm wondering if the driver software supports Vista or not.
  • Anonymous Dec 20, 2008
    same EXACT situation! Help!
  • Anonymous Dec 22, 2008
    But for the Mac OS.
  • 700 Answers
Look dor the hp imaging solution on the bottom of your computer screen. Click on it and when the screen come up clip on the button that is closest to what you are trying to do.
Posted on Dec 21, 2008
My canoscan LIDE 100 won't make multi copies of my drawings!
The scanner itself does not make copies. You scan and then reprint as many times as you need with a printer. Make sure your image settings are suitable for your printer eg save as a jpeg or pdf file and then reprint that. If you are trying to make your system do a function it is not capable of, you need to change the way you are doing it.
Mar 02, 2017 | Canon CanoScan LiDE 90 Flatbed Scanner
How do I get it off manual scan uniden bc72xlt when i turn it on it won't scan. thanks need help.
these scanners are a little hard to operate i have one of these it took me a while...Ok its because you have it on hold.when you turn your scanner on press your scan button.and your scanner should start scanning...
Jul 09, 2011 | Uniden BC72XLT Handheld Scanner
Sir, i want to scan a colour matter , i have 2570 cannon printer copier, please tell me or send software
it does not require any software just on the printer and keep the document on platen and click the colour button a green colour button.
Oct 17, 2010 | Office Equipment & Supplies
Scanning start problem
You need to have the scanning software running first, I use Picaso that comes with some windows.. You open the scan software and tell it what you are scanning and if it sees the scanner you can scan from the computer. If the software doesn't open when you press the scan button you may not have compatible software on your computer.
Dec 08, 2009 | Dell 946 All-In-One InkJet Printer
Printer works just fine, but scanner no longer has option to scan
Hi ,
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 19, 2009 | HP Photosmart C4280 All-in-One InkJet...
Can't scan from HP Photosmart C7280 to my Mac Computer
The best way to scan documents from the scanner to your computer is to use HP Photosmart Essential. If you don`t already have it installed it can be downloaded from the HP site. Once in the program it is very simple to follow. It is basically a point and click operation.
Let me know how you make out and we can do other things if this doesn`t work for you.
Please remember to rate me.
Feb 02, 2009 | HP PSC 2410 All-In-One InkJet Printer
Wanting to scan from scanner to computer
this happened to me too. i don't know how to fix it on the printer, but i scanned it through the computer. i went into the hp solution center, went to the scanning section, and told the printer to scan it from the computer. it worked fine. that way you don't have to save it to a memory card or anything. they went to the same folder all my other scans go to.
Jan 13, 2009 | HP Photosmart C4150 All-In-One InkJet...
Scanning
If you are getting this message when you are trying to scan from the All-In-One on a windows operating system.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Sep 28, 2008 | HP Photosmart C6280 Printer
Scanner problems
You need to have the full photosmart software loaded on the computer and to use this to scan to computer rather than using the buttons on the printer. This is a workaround rather than a fix but it should work
Fred
May 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
I'm trying to scan a picture and save it to my computer. I read the directions, it says to press scan menu.Then press scan to computer but, when I press scan menu it just has 2 options. Scan and reprint...
me too. What I just did, was open up word and then pressed scan. That worked, so maybe open the place you want the scanned item to go to and it will go there. You can tell I'm not a techie.
Apr 08, 2008 | Office Equipment & Supplies
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
321 people viewed this question
Ben Johnson
