Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Top Load Washer
How do we remove the agitators from the inside of the drum?
  • Anonymous Mar 20, 2014
    Top load washer
  • Anonymous Mar 21, 2014
    6 paddles inside, 3 larger and 3 smaller, one of the 3 broke loose. Looks like screws come from inside drum out to paddle,
There are 2 hub caps in the center of the rotors. Use a small screw drive and pop them out. There is a small torx head screw to remove in each. Once the screw is out, the rotors will pull right out. Caution, there is a left and a right, the underside is also marked left and right. You will find dimes, pennies, washers and even I found half of a credit card. Good Luck
Posted on Aug 09, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How to remove agitater from maytag washer
Remove the top cap(s), there should be a nut under it that holds the agitator in place. Remove the nut and pull the agitator off. It may be tough to get it out if its never been removed, over time lots of soap, dirt etc.; gets in there and clogs up the splines. Try pouring boiling water onto the splines, if its hard to get off.
Jul 01, 2014 | Maytag Neptune FAV6800AW Top Load Washer
The washer will not go into High Spin. I had the problem before, when a penny was lodged in one of the agitators. I need to know, how to remove the 2 agitators in the washing tub, to remove any debrei
You have to pry off the caps on the tumblers. Try not to produce any burs on them so on reinstall they dont snag the wash load.
Once you have the caps off you take a #20 Torx driver and back out the tumbler retaining screw the SM does not call that out.
Page 37 of the FAV6800A/FAV9800A Service Manual will detail this?
Do you have the SM? If not join this forum and download SM 16022808 Maytag Top Load Neptune Washer Service Manual
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune smells very musty. I have used vinegar, baking soda, and bleach but the smell wont go away!!!
This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The drum won't spin and belt will not stay on
i am sending you this breakdown, perhaps will help you to see if there is anything else broken or if you are missing a step in you installation of the belt. hope this helps.250
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Response to maytag question/your answer
OK, then it might be the tension wheel. They have a tension wheel, that keeps tension on the belt, that turns the drum. The bearings in it, might be worn out.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune stacked front load MLE2000AYW
I'm trying to remove the top cover in order to relace one of the fins inside the drum. The screws came loose and let go. I'm struggling to get the top off. Which screws in the from need removed to release the front? Thanks.
Jul 13, 2008 | Maytag LSE7806A Top Load Stacked...
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
LEAKS AND SQUEAKS
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
157 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
