Question about Sharp Conference Series XG-P25X Multimedia Projector
Sharp XG-P25X Projector
On all inputs exactly half the screen is projected all resolution settings being correct.
Picture is sharp and has propper color only left half the image shows
streched accross the whole screen
17 hours on lamp tried reinstaling.
???? Garrett
  • 31 Answers
Hi Garrett Use this sequence initially.Try turning the projector and source machine off. Turn source machine on. Turn projector on. I can not recall without checking the manual but look for the menu where you can set the source resolution. Some projectors allow quite comprehensive selection and others very limited to zero choice.
This is not a lamp issue, but the digital signal processing.
Typically the Pixel Map processor is not processing the pixel coming in to be mapped to the correct pixel on the display block.
If a digital problem in could either be a circuit malfunction or software (IC rom issue) which really you will need to take to a local authorised service shop.
Re your XG-PG25X We are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US339. includes freight. Excludes any local taxes.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Posted on Sep 10, 2009
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
Picture is pink and blue and not clear.
I am going to guess the model number here is correct, sometimes it is not-----that is a older set.
Not 3d looking but washed out or dull looking firstly.
If you go to a unused video input with the color on the set turned to zero what color is the screen? It if correct should be something black and white or grey.
One of the things you can do other than that is from the rear with set not plugged in, clean the 3 large lens==if dusty picture will be darker and dull looking---they are the light source for your picture.
let me know if screen is 3d looking, screen with color off is B&W, and if cleaning the lens helps.
SD TECH
Dec 04, 2012 | Sony KP-61XBR48 61" Rear Projection...
I suddenly lost the color on the screen and no manual adjustments seem to work to restore it.
I'm assuming that you have tried all the color temperatures, the full color setting, the full tint range and the correct input/colorstream to no avail. The only thing left that you can do then is to try to reset it - Menu, Picture, Reset button on the remote.
If even this has failed then the defect is in the tuner - you will have to call a repairman to replace it.
Oct 15, 2010 | Toshiba TW40X81 40" Rear Projection...
I don't have the remote, the picture in the TV does not cover the entire screen, it shows about 4to6 inches of emptyness at each side, what can I do to make the picture cover the hole screen?
To adjust the picture size on the television itself you would need a Sharp remote because there is a view mode button on it but there may be another way. If you are connecting a cable box or satellite tv receiver box to this television that remote should have an hd zoom # button or format button or aspect button that would adjust the picture size. The tv would have to be in the right input and the cable box or satellite tv receiver box would have to be set to the proper resolution according to what this tv is supposed to be able to display.
Aug 19, 2010 | Sharp 55R-WP4H 55" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
WD-52525 split screen
what are you using as input? On this set only digital channels can be the main picture. You can try the exch button to see if it comes back right also.
Aug 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Projection screen is pink
it's the resolution and input issue. make sure that the settings are correct and the resolution matches. then make sure the cable is fine.
Jul 30, 2009 | InFocus LP1200 projector lamp Projector...
I have a 50 inch tv that does not show the boarder of the screen, and when you press menu, or volume, there are two writings that come out in blue and pink. I dont know what is it, is the tv completely...
Disconnect it from any inputs and then try to enter the menu. Sometimes peripherals like dvd players will activate built in settings for compatability. If it persists, try working with the menu anyways, it could be a malconfiguration that is fixable through correcting the picture options, color, and sharpness.
Though I have seen a similar problem occur on a smaller tv after a lightning surge hit it. The picture was fine but the menu, channel number etc, went off screen half way. If this is the case the tv is probably ok but the controller card is scrap and needs to be replaced. I'd contact the manufacturer if it needs to be replaced they maybe able to supply you with one.
Sep 02, 2008 | Televison & Video
SCREEN RESOLUTION ISSUES - RED, GREEN, & BLUE
you can get a service manual for your set at this link I posted its listed under zenith projection tv R45w46 for $15.99 they e-mail it to you right after purchase and sign you up for free online tech support
http://servicemanuals.vstore.ca/
Apr 08, 2008 | Zenith R40W46 40" Rear Projection...
How do i connect my laptop
Assuming that the laptop is hooked up to the projection TV using the correct cables or connectors and still no video display on the TV, perhaps you need to lower down the laptops screen resolution first using your laptop's screen display before pressing the Fn + F? key.
To lower the screen resolution, right click on any clear area of your desktop, select Properties. click on the Settings tab, move cursor of Screen resolution to farthest left, Apply, Color Quality to lowest, Apply. Additionally, click on the Advanced button, Monitor tab, select lowest Screen refresh rate.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Sharp Conference Series XG-P25X Multimedia Projector Logo
225 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
