Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
Our 3yr old Sony Grand Wega KDF-55xs955 rear projection HDTV will not turn on. Red LED flashes 6 times.
  • 2 more comments
  • Anonymous Dec 27, 2008
    Our power/standby light flases 5 times. won't turn on. same problem?
  • Anonymous Jan 31, 2009
    Hi, same problem!!! tryed disconnecting, then used the wall outlet. same problem???.....
  • Anonymous Feb 16, 2009
    so does anyone have the part # for the thermal fuse?
  • mattallen149 Feb 24, 2009
    my sony wega wont turn on and the standby led flashes 9 times
Where is therm fuse location
Posted on Jan 30, 2009
    Problem Solver:
  • 41 Answers
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on Dec 05, 2008
I HAD THIS PROBLEM 5 TIMES AND ITS ALWAY HAS BEEN THE THERMAL FUSE.THEY FIXED MINE SO MANY TIMES THAT I WATCHED THEM AND NOW DO IT MYSELF. THE PART COST ABOUT $7.00 ONLINE,ITS THE LABER THAT GETS YOU
Posted on Jan 12, 2009
  • Daniel
    Daniel Nov 15, 2013
    What Part
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Aug 27, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv won't turn on anymore. The red light flashes 6 times then pauses for a couple seconds then starts flashing six times again. Just keeps doing it repeatedly
try unplugging the tv and waiting a minute and try it again if its still the same? It sounds like a Capicitor problem on the Power supply.
Dec 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't turn on...light flashes red 6 times
According to Sony's diagnostic chart, a six blink code means the plus/minus 17 volt line is not being supplied from the G1 board. (The Power Supply). I would replace the G1 board and that should fix your problem.
I hope this helps,
Skyassoc
Dec 15, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My KDF-55XS955 Wega shuts off by itlself goes into standby mode and flashed red 6 times, what can this be?
Replace the lamp...should solve problem. If you recently replaced the lamp, perhaps it is not in securely or the door is not secure. Check these and the reset lamp from main menue on remote. Hope this helps.
Oct 01, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
RED LED FLASHES 5 TIMES PICTURE ON SCREEN DARK-CAN HARDLY SEE IT
Ur tv might need the picture bulb replace,how long this tv had it bulb been replaced?
Sep 29, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blue cloud
That's OK, I been provided you technical info about TV problem.
Jan 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
559 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
